Go to Post FIRST robots definitely meet many commonly agreed upon definitions of robots. Some will disagree. Good for them. In my opinion, it's not worth arguing over. - Mikell Taylor [more]
Unread 31-10-2006, 23:22
987HighRoller's Avatar
987HighRoller 987HighRoller is offline
Vegas....Baby
AKA: Alex Sambvani
FRC #0987 (High Rollers)
987HighRoller has a spectacular aura about987HighRoller has a spectacular aura about
Lowered Center Wheel for 6 wheel drive
Hi,
We are testing a six wheel drive train and I was wondering how much some teams lower their center wheel. We are thinking about lowering it 1/8 inch....
Also, it would be nice if you also posted how soft your wheels are.
Thanks a lot
Team 987 - The High Rollers - Las Vegas, Nevada
2007 Las Vegas Regional Finalists
2007 Newton Champions
2007 Championship Winners! Thanks to 190 and 177
2008 IRI CHAMPS with 67 and 330
Unread 31-10-2006, 23:28
Joel J's Avatar
Joel J Joel J is offline
do you..
Re: Lowered Center Wheel for 6 wheel drive
lol, I was just looking into this same question.
229's 2005 robot had the wheels lowered by 3/16th of an inch, and it used the same rought top that IFI sells with its wheels. It didn't hop very much, but it rocked nastilly. Most robots at 1/8th of an inch don't rock unbareably, but if their CG is high, then they hop in an annoying way.
5/32nds of an inch is what makes sense right now, unless the CG is low, in which case 1/8". 3/16", I guess, is too annoying of a rocking motion for me.
There are threads on this, BTW, and I'm not a MechE, I just happened to have looked into this earlier.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 31-10-2006, 23:29
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
1/8" is, imo, the ideal lowering of the center wheel. When you say soft, you mean how much grip it gets? We used the McMasterCarr Roughtop conveyor belt material, which has a cof of 1.3 to the carpet. Worked pretty well, we were able to push just about anyone with our AM shifters.
Unread 31-10-2006, 23:41
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
1/8" with Wedgetop.
You have to be careful if you're welding your frame though. It's very easy for the frame to warp and nearly negate your dropped middle wheels. This happened on our practice robot this year.
2001-2004: Team 100
2006-Present: Team 254
Unread 31-10-2006, 23:48
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
swampthing in 2005 was 3/8"
Unread 01-11-2006, 01:11
edthegeek's Avatar
edthegeek edthegeek is offline
AMHS/Case Western Reserve Universit
AKA: Eduardo Arellano
no team (TKO)
edthegeek has a spectacular aura aboutedthegeek has a spectacular aura aboutedthegeek has a spectacular aura about
Send a message via AIM to edthegeek
We did that for our 2005 bot and for our 2006 bot(even though it was a 8 wheel drive). We lowered it about 3/8-1/4 inch, It was variable. We did this not by making the center holes lower, but by making bearing blocks for the back wheels ,which had slots. Therefore, the assembly was adjustable. This allowed us to adjust how quick or how unstable the chassis was when turning. For tread, we used SBR rubber (its the stuff that makes the soles of your tennis shoes). We also got it at McMaster. Our wheels were made out of milled 6061 Aluminum. To hold the rubber in place, we used Loctite 404. Loctite 404 was designed to glue drag racer tires to the hubs. However, I recommend against using the glue because it can be temperamental and result in the rubber peeling off. A better solution is to use pop rivets to hold them in.
"You do realize that most of the substances that you are inhaling right now are considered toxic in the state of California"
-Paolo to me while I am covered in Teflon and soldering.
"Stupid Chinese 6011 Alloy is stronger than we thought."
"Comrade, your sacrifice brings honor to the motherbot."
Unread 01-11-2006, 01:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
In 2005 we had the center wheel 3/16" lower which was fine. 1/8" probably would have been fine.
Unread 01-11-2006, 01:34
Guy Chriqui Guy Chriqui is offline
AKA: Guy Chriqui
FRC #0004 (Element)
Guy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really niceGuy Chriqui is just really nice
Our first year of lowering our center wheel we dropped it down 3/16, too much rocking for us. Last year we dropped it to 3/32 i believe and it worked alot better. Keep your CG low as possibly for the best handling when you do that. Also the rocking could be productive if you can drive it but its difficult.
-Guy
team4element
Unread 01-11-2006, 07:34
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We did .200" this year because we weren't sure if warpage would be an issue when we welded the frame. I would be comfortable decreasing it a bit but there are other factors beyond just the amount of rock to account for when we do our final drive train layout.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 01-11-2006, 07:49
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
This question has been answered before, specifically in the following thread.
CD Poll
It seems that your wheel's COF, placement, and size all play a part in determining how much to drop the middle wheel. The best answer is to play around with different drop heights and figure out what is best for your drivers. YMMV.
Best of luck,
BEN
Unread 01-11-2006, 07:54
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
I have used 1/4" over the years, but I now think 1/8" is enough. Actually, the more rigid your frame and wheels, the less offset you need.
Also, if you use pneumatic wheels, you can play with inflation levels of the center wheels to get more or less rock. In general, lower inflated wheels grip better so there are limits to what you want to do here, but it does give you some freedom.
Joe J.
Team #88, TJ2
Unread 01-11-2006, 11:22
Pat McCarthy Pat McCarthy is offline
FiM Volunteer
FRC #0067 (HOT Team)
Pat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond reputePat McCarthy has a reputation beyond repute
Send a message via AIM to Pat McCarthy
For the 2006 HOTBOT, we had the four corner wheels with rough top tread and the center two with wedge top tread. This made the center slightly higher than the outer wheels just with the tread difference. On top of that, we offset the outer wheels 5/16" or 3/8" (I can't remember which anymore). This worked extremely well for us.
2003-2006: FRC Team 67 - Drafter, Driver, Student Leader
2006 Volunteering: Kettering Kickoff Ref, Team Ford FIRST Robotics Invitational Ref
2007 Volunteering: GLR Field Reset/Repair; WMR Robot Inspector and Scorekeeper; MARC Referee
2008 Volunteering: WMR Planning Committee, WMR Scorekeeper, MARC Ref, IRI Scorekeeping, WMRI Scorekeeping & DJ
2009 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2010 Volunteering: Kettering District, MARC, IRI, and WMRI Scorekeeper/Field Power Controller
2011 Volunteering: Waterford District, West Michigan District, MARC, & IRI DJ
2012 Volunteering: Waterford District, West Michigan District DJ
Unread 01-11-2006, 15:23
RogerR's Avatar
RogerR RogerR is online now
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
in 2004 and 2006, 1369 dropped the center wheels by .100". in 04, we used beadlok wheels, and in 06, we used roughtop tread. both years, we had excellent maneuverability.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 01-11-2006, 15:46
in between teams
AKA: Luke Van Oort
Last year I believe our center wheel was lowered 3/16" and for wheels we used six of the KOP 8" wheels ground flat with SBR Roughtop attached using small wood screws. We were very happy with this setup, it turned easily, and pushed hard, although it was rather heavy. (Mostly due to twelve 54 tooth sprockets)
Team 1219: 2009 - Mentor
Unread 01-11-2006, 18:29
President, VEX Robotics, Inc.
2005 - 3 mm (just under 1/8")
2006 - 2 mm (just under 3/32")
In 2005 we had a bit more rock than we wanted. In 2006 we used 30% more current to turn than in 2005. We found that the closer your CG is to the center, the less the center wheel has to be lowered. We had a very stiff sheet metal chassis.
We will probably go with 3m this year.
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
Any pictures for Centered 2-Wheel Drive? phrontist Technical Discussion 9 30-04-2004 17:24
center-wheel drive Mercutio Technical Discussion 27 02-02-2004 21:19
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
