Arcade Drive
I was looking in the vex book and I noticed the Arcade style driveing. I set everything up and well...it did not work...does anyone have a solution as to why it didnt work? and how is the best way to set it up? and if i need a programming kit to do it please tell me right away so i can abandon all hope
![]() Last edited by Anfony : 01-11-2006 at 16:51. |
Re: Arcade Drive
the inventers guide has a couple misprints heres the new logic sectionlogic section
heres the control sectionhere and if these didnt help heres the vex downloads page scroll down near the bottem here |
Re: Arcade Drive
No, you do not need a programming kit. Just double check all your motor PWM cables and make sure they are all placed in the right motor port. And check your controller and make all of the selections are placed on the propper values. Good luck!
Re: Arcade Drive
yeah i was trying to figure out how i could wire an xbox controller and run the robot with that i thought it was a great idea and have been dieing to get it right
Re: Arcade Drive
I have the left and right motors in the fron right , how do i make the right and left rear move with the joystick, ive tryed it in 7 and 8 and all its doing is nothing....
| EasyC-FRC - Arcade driving help | Roger | Programming | 3 | 11-10-2006 15:03 |
| Arcade Mode (12) does NOT work | jakk | Programming | 2 | 10-07-2006 19:27 |
| Arcade Function | gabrielse | Programming | 1 | 08-02-2006 00:49 |
| vex programming arcade drive setting | Michael Leicht | FIRST Tech Challenge | 3 | 17-10-2005 21:26 |
| 1418's Fundraising Arcade Machine (Game Suggestions) | phrontist | General Forum | 29 | 26-10-2004 14:02 |
