Go to Post there should be a continuous cascade of knowledge spilling over to the less experienced team members and and continuous upward flow of members gaining experience. - ebarker [more]
Unread 01-11-2006, 19:33
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: pic: it's a Vex Holonomic Drive!
Originally Posted by artdutra04
Robot-centric. I didn't have any gyros or accelerometers around, so there was no way for me to program absolute (driver-centric) control. That, and at the time I programmed it in EasyC, and I was unsure if sine, cosine, and tangent functions existed. Either way, most people who I let drive that robot found even relative (robot-centric) driving very easy to drive.
Just curious how you got it to move in a straight line and spin at the same time then, as with a robot centric system, while spinning and translating, it begins to arc. For instance, if it spins clockwise while translating forwards, the "front" of the robot would move clockwise, causing a clockwise arc of motion (and eventually a circle that the robot moves clockwise along the perimeter).
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
Holonomic Drive Question Jeff Waegelin Technical Discussion 12 20-11-2005 21:23
vex programming arcade drive setting Michael Leicht FIRST Tech Challenge 3 17-10-2005 21:26
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
