Go to Post I'm thinking they subscribe to the thought that "the best offense is a good defense". They are from New England, after all. - Travis Hoffman [more]
Unread 01-11-2006, 23:08
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: pic: it's a Vex Holonomic Drive!
Originally Posted by Lil' Lavery
Just curious how you got it to move in a straight line and spin at the same time then, as with a robot centric system, while spinning and translating, it begins to arc. For instance, if it spins clockwise while translating forwards, the "front" of the robot would move clockwise, causing a clockwise arc of motion (and eventually a circle that the robot moves clockwise along the perimeter).
If you do not compensate for that while driving the robot, then yes, that is what it would do. But if you start driving forward and start to rotate to the right, if you move the left (transversal) joystick to the more to the left, you can compensate for the spin and more or less the robot will continue to move "forward" while spinning. With only relative control, it takes a lot more driver skill to translate while transversing.
Art Dutra IV
世上无难事,只怕有心人.
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
Holonomic Drive Question Jeff Waegelin Technical Discussion 12 20-11-2005 21:23
vex programming arcade drive setting Michael Leicht FIRST Tech Challenge 3 17-10-2005 21:26
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
