Go to Post Not all current students are math dummies. Not all 1960's students were math geniuses either. - Clem1640 [more]
Unread 02-11-2006, 09:42
Back after 4 years off
FRC #5279
Re: !HELP! IM STUCK IN A SUBROUTINE!!! !HELP!
Assuming he didn't change the comment at the beginning of the code (which I am guessing he didn't because other wise the line numbers don't do much good) then he initialized time in the right place.
The only problem I could see there is if you just declared time and didn't initialize it. Assuming you initialized it as 0 I don't see that as being your problem. I am not sure if it is enough to cause the problem you have but at the very least it is sloppy to return a value through the function if you aren't assigning it to anything.
If you still can't figure out the problem, post all of your user_routine_fast.c and we can probably help more.
James
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
RC Controller Stuck bhk88 Programming 1 31-01-2006 17:46
Stuck on Camera Mount busterblade16 Programming 2 14-02-2005 22:07
stuck in programming mode Shu Song Control System 2 29-04-2004 16:44
help! Am really stuck!!!! pagemauck Programming 8 29-01-2004 12:38
guy stuck in toilet! robot180 Chit-Chat 8 14-11-2003 22:27
