Go to Post The numbers that I gave were purely theoretical and should not be considered realistic - Karibou [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 02-11-2006, 21:58
SWIM's Avatar
SWIM SWIM is offline
SomeoneWhoIsntMe
AKA: James Meintjes
SWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really niceSWIM is just really nice
[OCCRA]: A friendly reminder from team #2...
Make sure to check all your batteries in your robot before competition. Even if a battery can charge to 12.9v, that doesn't mean that it will hold that charge. There's always a possibility that the battery will start dropping to ~6v while you need to push an opposing bot, causing you to lose the round.
Unread 02-11-2006, 22:38
CBaoth CBaoth is offline
OMG HAX 4 L1FE NOT JUST CHANUKAH!
None #1489 (Fighting Tuna)
Team Role: Student
CBaoth will become famous soon enough
Send a message via AIM to CBaoth
Re: [OCCRA]: A friendly reminder from team #2...
dude you need to chill
Unread 02-11-2006, 22:46
SWIM's Avatar
SomeoneWhoIsntMe
AKA: James Meintjes
probably
Unread 02-11-2006, 23:10
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
a good way to test the batteries for capacity is to perform a load test on them.
I belive a battery that is still at 100% capacity should be able to run for about 1 hr with a 9amp load. (at least the batteries we have are like that, they have a 12AH rating, however that is the rating at a very slow (1 or 2 amp) load.
That is what our team (Team 469) did and we had no battery problems today, however we did discover that many of our batteries were in rather poor shape and therefore we decided not to use those batteries today during the competition.
Brief explination of batteries, sent out by one of Team 469's wonderful mentors, Tim Downey
The basic battery is formed by 2 dissimilar metals separate by a dielectric. In the standard lead acid battery consists of lead and lead oxide plates (lead/rusted lead) separated by sulphuric acid. The lead oxide scale can fall off of the plate and float around in the dielectric solution. If this comes in contact with between the lead plate and the lead oxide plate, the result is a shorted cell. This condition is easily measured with a volt meter. The battery output will be approx 10 vdc instead of 12. The batteries we have are of the gel-cell type. The dielectric is a gel instead of an aqueous solution. The result is less occurrence of the shorted cell. The gel cell creates a different problem, one less easily identified. When a battery is heated, as happens during an over charge cycle or during a rapid discharge cycle, H2 gas is released. In a conventional lead acid battery, the gas is easily dispelled from the acid. This creates a dangerous explosive condition but does not damage the battery. In a gel cell battery however, the gas is trapped inside of the battery. This is safer from an explosive stand point (that is why UPs systems and fire alarm systems use gel cells) but the gas bubbles form inside the gel and result in a diminished dielectric/plate surface area interface. The result is a diminished power output. This is not easily measured with a volt meter. In fact, the voltage readings will be normal. The damage will not be noticed until the power (current * voltage) is required.
Conclusion:
1) do not shake a battery - you may short out cells
2) do not over charge or over discharge a battery or you will lose available power
3) do not pick your nose in public (you will embarrass the rest of the team)
(thanx to Mr. Downey for that wonderful descrition)
Unread 03-11-2006, 08:57
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
We also load test our batteries before we put them in. We also had a couple of risky looking batteries and I put them right back in the box and grabbed another one. Ours usually last about an hour fully charged these occra robots don't consume as much power as you think. You could probably run 2 matches on a battery if it is fully charged, but I would NOT recomend it.
-Josh Murphy-
Unread 08-11-2006, 08:04
wackiejackie7nf wackiejackie7nf is offline
AKA: Jackie Duchene
None #0017 (Awesome-O)
Team Role: Student
wackiejackie7nf is on a distinguished road
Send a message via AIM to wackiejackie7nf
Is this like a suck up to the judges thing, or is this cause you lost because some team screwed up? this is NOT only to you, I'm just kind of sick of all the stuff just plain sucking up to get the foundation award....OCCRA is supposed to be about the actual robotics and learning and technology , not about some shiny award!
Unread 09-11-2006, 23:13
AKA: Jackie Duchene
Team Role: Student
Ok, somebody on my team said that that comment, about the batteries was becuase you guys got a team mate a few times that didnt do it...I have no idea why i was a ...... for that, so I"M SORRY! just frustrated with that one, if i could delete a post, I'd delete that one ...CAN i delete a post?
Swim, what did you say that got deleted?
*Simple is Good*
Unread 09-11-2006, 23:41
SWIM's Avatar
SomeoneWhoIsntMe
AKA: James Meintjes
I was just saying that the reason I made the thread was because we lost because of a broke battery, not because we're trying to suck up to anyone
Unread 09-11-2006, 23:48
AKA: Jackie Duchene
Team Role: Student
I know i reread it and stuff just now, I'm an idiot, ignore it please! sorry again!
*Simple is Good*
A friendly reminder... mechanicalbrain Chit-Chat 0 05-01-2006 22:20
Signatures - A friendly reminder from your CD Mods. Rich Kressly General Forum 11 15-04-2005 22:44
A Friendly reminder on sanitation Ryan Albright General Forum 19 04-02-2005 15:36
Reminder from a posting vet Andy Baker General Forum 13 26-08-2003 23:39
Image Discuss: Friendly Gear Greeting from MOE, 365! CD47-Bot Extra Discussion 1 29-01-2003 21:10
