Go to Post Its great for us as mentors to see students teaching other students and a robot being built from scratch without us. Maybe someday they won't need us at all!!! - DR3381 [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Unread 05-11-2006, 09:08
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: pic: Team 610 Off-Season Tank Drive Prototype
Just wanted to share a pic of our tank tread tensioner design. We came up with this design after breaking so many belts in 2004. We only broke 1 belt in 2006, and we believe that was due to someone overtensioning the tread in the pit.
Basically, for each of our tread modules, the non-driven pulley wheel axle rides inside slots on the frame. A u-shaped 1/4" aluminum assembly straddles the pulley wheel. This U-assembly is pushed by a bolt which passes through a threaded hole on a thicker frame member. Turning the bolt pushes against the U-frame and provides the tension adjustment. A jam nut lets us lock the bolt into position once the sweet spot has been found.
Big? Yes. Beefy? No doubt. But the results speak for themselves.
Name:	Team 48 Tensioner.JPG
Unread 06-11-2006, 00:29
Andy Y. Andy Y. is offline
FRC #0610
Andy Y. is on a distinguished road
Sweet Design. We were thinking of the same thing, except instead of an adjustable screw, Derek (lab technician), our mentor, and I discussed a spring loaded system where a piece of u-channel would keep constant regular pressure on the 2 pulleys maintaining tension. Ofcourse we would have to calculate the tension needed to ensure we don't over/under tighten the belt like you mentioned. Thanks for the pic ; sweet drive design too.
Andy
Unread 06-11-2006, 01:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
45's tensioner in 2003 was pretty cool
2001-2004: Team 100
2006-Present: Team 254
Unread 06-11-2006, 01:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally Posted by Cory
That's interesting. I'd seen that pic quite a bit before, but never realized exactly what that piece did. Now I know!
There was a pretty good discussion on tracks a while back here. It's worth reading.
pic: 213 - Drive prototype teaser Tyler M. Robot Showcase 10 07-01-2007 20:56
Extreme Off-Season Events by Team 759 Rich Wong Off-Season Events 3 04-05-2005 07:02
pic: Team 610-Teaser Type Thingey n_0163 Robot Showcase 9 02-02-2005 14:13
pic: 226 Off-Season Prototype Chassis Matt Reiland Robot Showcase 2 01-02-2005 19:33
pic: TEAM 610 ROBOT CD47-Bot Robot Showcase 13 29-03-2003 21:40
