| View Poll Results: Should I go with a single stage, or multistage coil gun? | |||
| Single stage, keep it simple. |
4 | 16.67% |
| Single stage is for wimps, go for multi!! |
13 | 54.17% |
| I have no idea what the difference is. |
7 | 29.17% |
| Voters: 24. You may not vote on this poll | |||
Re: Solid core inductance
Well mainly because the power supply i have is a kit I built a few years ago, and only goes up to 12 volts. But the main reason is i want to be able to finish the coil gun and know that i made it from "scratch."
That, and the fact that i need to drag my presentation out to a full 40 minutes, so I'd rather go through the formulas, and show how the boost converter works rather then just say "well this power supply charges the caps". But yes, using a power supply would be MUCH easier, but just ask my mentor, "easy" is not in my vocabulary ![]() |
The simplest thing to do in this situation would be to get a line operated high voltage transformer with a secondary winding of 300 volts center tap. (I am guessing right now at the numbers) In a full wave rectifier, you might be able to get 200 volts DC to charge the caps or to fire the energizing coil. Transformer cost in the $50 + range new, total supply less than $100 (fuse, line cord, diodes and trerminal strips). This is a common transformer in tube type equipment and might be found in a junk TV or radio or at a Hamfest.
What Phil is trying to make is what some people call a "whistler supply". It uses a low voltage DC power source like a bank of batteries, running an oscilator to produce an AC voltage capable of driving a low voltage primary winding on a transformer. The secondary winding is a high voltage winding much the same as the linear supply described above. The difference is the transformer core. At 60 Hz you need a lot of iron to couple from the primary to secondary windings. At 1.5 kHz or above, the core becomes more efficient and so the need for a heavy iron core is diminished. MOst often these supplies are actually running at much higher frequencies like 10-15 kHz. When they operate, the supply can be heard as whistling. This type of supply is comon in a camera photo flash unit when first turned on. Since you need an oscillator and high power driver (sometimes the same device) this is a much more complex device. The upside is the transformer is a fraction of the weight of a line operated supply. However, 200 volts is still 200 volts regardless of how you get there. High voltage batteries were plentiful at one time when portable radios were tube operated. Finding them now is next to impossible. |
| Inductance of CIMs | phrontist | Electrical | 13 | 06-01-2006 09:17 |
| is it a solid or a fluid? | John Gutmann | Technical Discussion | 11 | 05-08-2005 01:05 |
| Armored Core 3 AC Designs/Reviews | MarkF | Chit-Chat | 4 | 24-05-2003 18:13 |
| solid edge solid works | ceileachair | Inventor | 1 | 21-01-2003 22:03 |
| Are you hard core or not? | Joe Johnson | Championship Event | 7 | 25-04-2002 23:05 |
