Go to Post :( The Internet just ate my post. - Greg Marra [more]
Unread 05-11-2006, 17:17
Nathan's Avatar
Nathan Nathan is offline
FRC #1501 (Team T.H.R.U.S.T.)
Nathan has a spectacular aura aboutNathan has a spectacular aura aboutNathan has a spectacular aura about
CMU 2 cam with Vex
Hi, one of my mentors wants me to hook up a CMU cam to a vex robot. But I'm not sure how to hook up power to it? Has anyone ever done this? Should I just hook a PWM cable from the camera to the vex controller?
Thanks for the help,
Nathan
Unread 05-11-2006, 18:27
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
Re: CMU 2 cam with Vex
Nathan
Try this thread
Unread 05-11-2006, 20:36
Nathan's Avatar
Wow, thanks. Exactly what I needed!
Unread 05-11-2006, 21:36
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Originally Posted by intellec7
Try this thread
I made that work a couple months ago. I used Kevin's camera code moved to a vex MPLab project.
Eric Haskins KC9JVH
Unread 05-11-2006, 21:55
Nathan's Avatar
Where could I find Kevin's code? That would really help alot!
Thanks,
Nathan
Unread 05-11-2006, 21:57
AKA: Eric Haskins
www.kevin.org/frc
If you want any other help PM or e-mail me Haskinseric@hotmail.com.
EDIT: I tested my vex with the code in frc_camera_s.zip. It may work with version 2 and/or the full version of the code, but I know the first simple version works.
You will need to follow the instructions in the readme to move the code to an EDU/Vex robot. I know it says its for the EDU only, but the process to move it to a VEX is the same.
Also I was using the Radio Shack programming kit, but using MPLab IDE and IFI Loader. This will work with MPLab, but I don't think its possible with EasyC, because you wont have access to the serial ports.
Sorry for the long edit, but I thought of alot after I typed the my response.
Again, if you want any other help PM or e-mail me Haskinseric@hotmail.com.
EDIT Again: If you need a copy of the MPLab default code for a vex you can download it from http://www.vexlabs.com/vex-robotics-downloads.shtml. Here is a direct link to the file http://www.vexlabs.com/docs/vex-startup-code.zip. You can also get IFI loader from that page.
Hope this helps,
Eric Haskins KC9JVH
Unread 05-11-2006, 22:14
Nathan's Avatar
Thanks! And I already use MPlab so that shouldn't be a problem. By "the first simple version" do you mean frc_camera.zip?
Thanks again,
Nathan
Unread 05-11-2006, 22:16
AKA: Eric Haskins
I used frc_camera_s.zip.
frc_camera_s.zip
EDIT: You do need a different version of the default code for a vex. The code from an FRC controller will NOT work. You can download it from the link in my post above.
Eric Haskins KC9JVH
Unread 11-11-2006, 13:18
Nathan's Avatar
Eric's been helping me via e-mail (Thanks Eric!), and now I've gotten the cables all hooked up. But when I try to integrate Kevin's camera code, by adding "camera.c" and "camera.h" to my MPlab project, I get the following error:
Error - could not find definition of symbol 'Serial_Port_Two_Byte_Count' in file 'C:\VexCode\camera.o'.
Errors : 1
BUILD FAILED: Sat Nov 11 12:53:45 2006
And unfortunately I can't get it to go away... Any idea's why I'm getting this?
Thanks,
Nathan
Unread 11-11-2006, 14:13
That's defined in Kevin's serial_ports.c/h files.
Did you include those in your project?
Unread 11-11-2006, 14:22
Nathan's Avatar
No, I didn't. I guess that was the problem, thanks Now, do I need to include the rest of the Kevin's .c/.h files to my project, or will just having the camera.c/h and serial_ports.c/h files be ok?
Unread 11-11-2006, 15:42
AKA: Eric Haskins
If you follow the instrustions in the Camera Readme, tracking readme, and the serial port readme. Your robot should be working in no time.
If you are planning to write your own tracking code you don't need to follow the tracking readme to integrate tracking.c/.h/
Eric Haskins KC9JVH
Unread 11-11-2006, 16:24
Nathan's Avatar
Thanks. And I've been trying to read all the readme's/.c/.h files, and is this how you track an object:
Initialize_Camera();
Camera_Idle();
Track_Color();
Is that how you do it?
Thanks,
Nathan
Unread 11-11-2006, 20:55
AKA: Eric Haskins
If you have integrated the serial and camera code properly you can put this code in porcess_data_from_master_up
Camera_Handler();// this  updates the camera data.
Servo_Track();// this is in tracking.c, so you must include tracking.h.
You can look at the code in kevin's frc code, or the code I e-mailed you for a better explaination.
Feel free to e-mail me.
Eric Haskins KC9JVH
CMU cam Booger Programming 3 18-07-2006 00:00
CMU Cam on an EDU-RC Redneck Programming 2 11-02-2006 14:55
CMU-Cam power QuantumNinja Programming 1 01-02-2006 21:14
grrr need help with my cmu cam lilrican13 Programming 6 18-01-2006 00:14
CMU Cam GUI Arc736UV Programming 2 15-03-2005 19:26
