Go to Post 50% of the time that 330 used mcmaster 2717T51, we went to Einstein. Your mileage may vary. - Joe Ross [more]
Unread 06-11-2006, 01:15
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Only one side moves!?!?
Hey all,
I've been having trouble with this PID code. I made some change to the code in the past but I haven’t noticed that only one side does the correction since a few days ago.
I've tried to debug and all of that good stuff, but I haven’t been able to get my finger on the cause of the problem. Here’s the code!
	if (currentX == 127)
		// printf("CurrentX: %d Gyro Angle: %d\r\n", currentX, cur_heading);
		temp_currentY = (currentY - 127 + error);
		printf("temp_currentY 1: %d\r\n", temp_currentY);
		temp_currentY = ((temp_currentY * 0.59) );
		printf("temp_currentY 2: %d\r\n", temp_currentY);
		temp_currentY = (127L + temp_currentY);
		printf("temp_currentY 3: %d\r\n\r\n", temp_currentY);
		temp_currentY =	Limit_Mix(2000 + temp_currentY);
		temp_currentX = (currentX - 127 - error);
		printf("temp_currentY 1: %d\r\n", temp_currentX);
		temp_currentX = ((temp_currentX * 0.59) );
		printf("temp_currentY 2: %d\r\n", temp_currentX);
		temp_currentX = (127 + temp_currentX);
		printf("temp_currentX 3: %d\r\n\r\n", temp_currentX);
		temp_currentX = (254L - temp_currentX);
		temp_currentX =	Limit_Mix(2000 + temp_currentX);
			pwm_rightDrive_cim = pwm_rightDrive_fp = Limit_Mix(2000 + temp_currentX + temp_currentY - 127);
			pwm_leftDrive_cim = pwm_leftDrive_fp = Limit_Mix(2000 + temp_currentX - temp_currentY + 127);
		if(currentY == 127)
			pwm_rightDrive_cim = pwm_rightDrive_fp = Limit_Mix(2000 + currentX + currentY - 127);
			pwm_leftDrive_cim = pwm_leftDrive_fp = Limit_Mix(2000 + currentX - currentY + 127);
			Reset_Gyro_Angle();
		else
	else if((ratechange < 10 && ratechange > -10) && (currentX == 127))
		Reset_Gyro_Angle();
	else
		Reset_Gyro_Angle();
Any suggestions? Thanks!
Unread 06-11-2006, 11:15
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: Only one side moves!?!?
What kind of variables are temp_currentX and temp_currentY? If they're char or int, that multiply by 0.59 is going to round down to 0, which can cause unexpected results.
Matt Krass
Unread 07-11-2006, 02:07
kiettyyyy's Avatar
They are just normal int's. I tried sticking 0.59 as a floating point value by putting an F at the end, but that still didn’t work. I'll give it a try tomorrow afternoon. Thanks Matt!
Unread 07-11-2006, 12:32
psquared89's Avatar
psquared89 psquared89 is offline
AKA: Pat Pannuto
FRC #0245 (Adambots)
Team Role: Driver
psquared89 is a jewel in the roughpsquared89 is a jewel in the roughpsquared89 is a jewel in the roughpsquared89 is a jewel in the rough
Floating point calculations on the MCC18 are always a little sketchy. Also, true PID calculations take more processing power than it has. If you really want to implement PID I'd suggest looking at a co-processor. If you're interested, our team used one last year, and we're in the process of writing a guide for how other teams can create their own.
Check out the beginnings of our guide on our website. We're in the process of writing the guide right now, by the end of the month it should be complete so check back often.
At the end of the game, the King and the Pawn both go back into the same box.
~ Italian Proverb
adambots.com
Unread 07-11-2006, 13:25
Matt Krass's Avatar
AKA: Dark Ages
Even so, integers could still make for flaky numbers. My recommendation is multiply it by 59, then divide by 100, fundamentally it's still the same, but that operation is much faster, and more supported by the processor, with minimal (and predictable) data loss in the form of rounding error.
Matt Krass
Unread 11-11-2006, 14:51
kiettyyyy's Avatar
Ahh... So that was the problem! Since the temp_currentX and temp_currentY were defined as "int", the system only had temp_currentX with the correction going on one side. That seemed to fix it. Thanks everyone!
Only one side moving Idaman323 Programming 11 21-02-2005 00:00
2 human players on one side? Sscamatt Rules/Strategy 11 22-02-2004 23:34
Navigate.c Current Sense code=only one polarity Dale(294engr] General Forum 1 05-02-2004 16:25
I guess there can only be one . . . archiver 1999 0 23-06-2002 22:46
In The End, There can be only one..... archiver 1999 6 23-06-2002 22:02
