Go to Post Some things in life are far more important than Robotics. - IMDWalrus [more]
Unread 06-11-2006, 17:26
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Question ???Abnormal Camera Initialization????????????
Ok ive fixed my autonomous coding now it works great no more subroutine problems but now im getting the following Printfs on the terminal window when i load the code, i even tired to load camera code before any of my autonomous tweeks.
Camera: Initialized abnormally with code 131
Camera: Initialization state = 1
Camera: Initialization state = 2
Camera: Initialization state = 3
No camera data...
No camera data...
it just indefinatly repeats and the camera doesnt move at all
im really confused to why this is happening, any thoughts?
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 06-11-2006, 18:40
Re: ???Abnormal Camera Initialization????????????
131 means the camera communication isn't working.
There are a bunch of reasons this could be happening from camera power, to two serial connections hooked up to the camera at the same time.
Search the CMUCAM forum for "131" and you'll find a few past threads on this error.
Unread 06-11-2006, 18:46
No camera data...
It's reasonably self-explanatory: the RC is not getting any data from the camera. Check that the TTL/RS-232 converter circuit is properly attached. Check that the communication wiring between the camera and the RC is correctly connected. Check that the power connection is solid from PWM pins to camera.
And make sure a fully charged backup battery is plugged in.
Unread 06-11-2006, 18:54
AKA: Cameron Dennis
i did, those are all 100%, i think im going to try a coding thing i found on another thread that resets the boot initialization flag
www.frc1266.com
Unread 07-11-2006, 00:45
Kevin Watson's Avatar
La Caņada High School
FRC #2429
No camera data...
No camera data...
Check out the camera FAQ at http://kevin.org/frc/camera/.
-Kevin
Kevin Watson
http://kevin.org
CMUcam initialization time DanDon Programming 11 31-12-2006 16:57
Possible bug in memory initialization? eugenebrooks Programming 3 08-04-2006 09:22
Search Servo Initialization Caution Keith Watson Programming 3 09-02-2006 07:49
Reciever Initialization problem PuiChi Programming 1 26-01-2004 23:54
Master uP Initialization Routine Ulibrium Technical Discussion 5 24-01-2002 16:43
