Go to Post I think Dave has been spending time on icanhascheezburger. Either that or the fumes from his rendering machines have affected the grammar control portion of his brain. - rsisk [more]
Unread 07-11-2006, 11:56
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Custom Chargers for backup battery
Originally Posted by Al Skierkiewicz
Tris,
I believe the "may" in the language is meant that you may or may not charge the battery in the robot. If you choose to charge in the robot then the IFI charger is to be used.
Isn't that the first "may" in the rule? I'm considering the second one (i.e. the ninth word of the third sentence).
My point is simply that they failed to restrict alternatives (in the case of the on-robot charger) by only describing what's allowed, and not saying what's disallowed.
And of course, I'm pretty sure that they intended for teams to use only the IFI charge circuit for on-robot charging. It's just that in order to say that, they should have repeated "is to be" in place of "may", or qualified it with "only". Sure, it's lawyerlike to insist upon this point, but it's also crucial to consider all the possibilities when interpreting an engineering specification.
By the way, I should qualify what I said above about COTS chargers; I meant for that to refer to off-robot charging only....
Automatic battery chargers only? sanddrag Electrical 1 12-01-2005 23:38
[OCCRA]: different battery chargers? no chance OCCRA Q&A 1 28-10-2004 05:34
Off-topic battery stuff. FotoPlasma Electrical 4 06-01-2003 12:19
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
Voltage Range of Analog Inputs Ulibrium Electrical 21 15-02-2002 14:11
