Go to Post The only tool that will work to get our robot done in time will be a prayer rug. - Rick TYler [more]
Unread 09-11-2006, 02:31
cdennisxlx2's Avatar
cdennisxlx2 cdennisxlx2 is offline
Team San Diego Web Liaison
AKA: Cameron Dennis
FRC #1266 (The Devil Duckies)
cdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to beholdcdennisxlx2 is a splendid one to behold
Arrow Limit Switches + camera = Error 131
Ok i think i figured out why i was getting the 131 error, he had recently installed 2 limit switches, well those 2 plus the 6 pwm cables for our dipswitch and the pwm cable from the pressure switch made the RC harware LED to light saying +5V Output low, thats why i was getting the 131 but now i need to know how i can fix that, im hoping just taking 3 of the pwm cables from the dip switch and only programming 3 autonomy codes might do it so there isnt all of those pluged into the port, any thoughts?
Team San Diego Robotics Web Liaison
Webmaster and Technical Advisor for the San Diego Regional Planning Committee.
Official Score Keeper for the San Diego Regional
www.sandiegoregional.com
www.frc1266.com
Unread 09-11-2006, 12:09
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: Limit Switches + camera = Error 131
Maybe your switches and the camera combined are simply drawing too much current.
1.) Put the camera on a PWM output where it is supposed to go, not on a digital I/O port.
2.) Put a large value (10k-ohm or so) resistor in series with each of your switches.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 09-11-2006, 12:24
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I never had any problems like that, and I had more than that on the robot. We had two limit switches, 5 toggles for autonomous, and 3 other toggles for other options.
It sounds like you have to camera connected to one of the inputs, and a PWM, because the PWMs are unregulated they get the straight 7.2v from the backup battery so the 5v supply should not be affected. Unless the main battery is dead and the controller is running off the backup.
Eric Haskins KC9JVH
Unread 09-11-2006, 12:31
REVving up for a new season
FRC #2848 (All-sparks)
Those darn C.H.A.O.S. errors. ......please return to your regularly scheduled program.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 09-11-2006, 14:17
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
I agree with you, there is no reason that the voltage should be so low if things are plugged in correctly with a fresh battery. I would check for a short in the system. You may want to try selectively unplugging things until the problem is cleared starting with things that were recently added. Also multimeter should be able to help you spot a short relatively quickly.
Unread 09-11-2006, 14:57
AKA: Cameron Dennis
Fully charged main battary and fully charged backup, and the camera is pluged into a pwm port not an digital io port, all i know is when i plug a limit switch into the rc i get the RC hardware error and my camera doesnt work, and it doesnt matter what limit switch it is or pwm cable we have switched them out also.
www.frc1266.com
Unread 09-11-2006, 15:10
That certainly sounds like it's your limit switches.
How did you wire them?
Only the ground and signal wires are used right, not all three (i.e., not power)?
Unread 09-11-2006, 15:42
Another possible problem along those lines would be if the switch was shorting between ground and power. If the switch is wired as normally closed, the short would occur as soon as it was plugged into the RC.
Alternative to limit switches? RbtGal1351 Electrical 27 10-12-2005 15:30
limit switches stephenthe1 Programming 28 11-05-2005 16:37
Limit Switches help. Xufer Programming 9 21-04-2004 21:21
Limit switches Team168 Programming 8 10-02-2003 16:22
Limit Switches/Pots Brett W Technical Discussion 3 28-01-2003 14:25
