Go to Post You can design and theorize all you want, but the sooner you get to testing your ideas and seeing how things actually work, the better off you will be. - Andy Baker [more]
Go Back   Chief Delphi > Other > VEX
Unread 10-11-2006, 22:31
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Hello Peoples, How can I be like you?
Hi Guys, I am sitting here with our rookie programming team (I know nothing about programming as I'm the part of the design and build team so I am learning too right now) and we are trying to integrate our code into the vex default code so we can still drive around and have our code work. Right now our code overwrites the default code so our arm works but the driving doesn't. How can we put the two codes together?
Thanks in advance
Vova
Unread 10-11-2006, 22:38
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: Hello Peoples, How can I be like you?
I am not great at programming. If you start with the default code that is in the samples, then build the rest of your system on it then things will go better. If that doesn't work, go to http://www.team188.com and leave a post there for Shawn Lim. We are in the Toronto area so maybe we can talk by phone as well.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 10-11-2006, 23:29
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
If you post your FRC code I can take a look, buut without your code I can't really help.
If would like help, but don't want to post your code online send me a message at haskinseric@hotmail.com.
Eric Haskins KC9JVH
Unread 10-11-2006, 23:36
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
I will write it out for you if that's ok since I am at home and the code is at my friends house:
it's a while cycle with a "if else"
if limit == 1
motor 5 (127) //stopped position
motor 6 (127) //stopped position
else
motor 5 (0)
motor 6 (0)
wait 1000
motor 5 (127)
motor 6 (127)
i know it doesn't follow any programing rules but that's what we are trying to put into the default code
Unread 20-11-2006, 15:43
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
You should check out easyC for VEX it is designed for people just like you!
I promise that you will be able to program your robot in under 15 minutes to drive and move your arm. Just look at the help file real quick and you should be on your way.
You can download a trial here: http://www.intelitekdownloads.com/FVC2006/
If you need a FRC copy PM and I'll set you up with a copy of that.
How many extra batteries should you bring, and where can you buy more? haverfordfords Electrical 6 08-02-2005 22:01
Peoples Feelings on Atlanta's Nationals(like as many people to respond as possible) BlazinFire47 Championship Event 39 23-04-2004 09:39
Hey all you smart peoples! Alex Cormier General Forum 7 24-01-2004 22:03
Would you like to learn how to sign? OneAngryDaisy General Forum 0 05-03-2003 20:11
How did you guys like Nationals? archiver 2001 0 24-06-2002 03:17
