Go to Post Intent is determined by those that are doing, not those that are watching. - meaubry [more]
Go Back   Chief Delphi > Other > VEX
Unread 13-11-2006, 16:10
Re: Problems with Updating VEX Controller Master Code
From the IFI/Intelitek Loader Help search for "Master Code":
  1. Open the intelitek loader.
  2. Select download Master code from the Options menu.
  3. You get a file select pop-up that "sees" .bin files.
You can also use the stand-alone IFI_Loader to download the .bin file.
Step-by-step directions come bundled in the Vex Master Code v7 .zip (although you don't use that Master Code version with EasyC).
Unread 20-11-2006, 15:37
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Goto the options menu in the Intelitek Loader. Click "Download Master Code"
For more help see the help file under "Downloading Master Code"
To Download anything Vex and easyC related goto:
http://www.intelitekdownloads.com/FVC2006/
Impossible to truly to vex holonomic with default code? chaoticprout FIRST Tech Challenge 3 08-05-2006 20:40
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Master Code 11? SteveO Programming 5 22-04-2005 19:48
Master Code? HolyOne207 Programming 4 12-01-2005 22:32
ADC problems with C library and new code Larry Barello Programming 1 09-01-2004 22:31
