Go to Post Don't Canadians spell it that way? Someone should cheque on that.... - Travis Hoffman [more]
Unread 13-11-2006, 16:56
xur2007 xur2007 is offline
FRC #1474
xur2007 is an unknown quantity at this point
How to hook up a Police light on the Robot??
Need some suggestions. How would you hook up a Police Light or a light bar onto a FRC Robot? We want to attempt it for public relations purposes.
Example:
http://www.theelectronicsshop.co.uk/police%20lights.htm
Any other cool LED light ideas?
-Ray
Unread 13-11-2006, 17:06
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: How to hook up a Police light on the Robot??
I see that your number is fairly high, so I'm guessing your team joined after 2003.
2003 was the last year of the rotating light you speak of as an actual implementation in the kit of parts for the robot.
If no one answers your question before I have a chance to, I will grab the manual from those years gone by and get the correct specs on how to hook up the rotating light as put forth by FIRST.
It should still work on the newer electrical systems provided with the FRC kits of today.
Unread 13-11-2006, 17:26
Alex698's Avatar
Alex698 Alex698 is offline
Sparky
FRC #2449 (Out of Orbit Robotics)
Alex698 is a jewel in the roughAlex698 is a jewel in the roughAlex698 is a jewel in the rough
Send a message via AIM to Alex698
I can answer this one. A spike. M+ is positive m- is negative. actually it really doesn't matter because the light part isn't polarity sensitive, and the motor will either go forward or in reverse. If you are in a FRC comp you can just hook the positive lead in a circuit panel beaker-side. and the negative to the negative area. ALL SET!
edit: one problem... the ones listed are 220V you'll need to buy 12vdc ones otherwise it could get complicated with inverters.
Eat, Sleep, Build Robots
Unread 13-11-2006, 18:01
BobC's Avatar
BobC BobC is offline
Big Daddy
FRC #0176 (Aces High)
BobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to allBobC is a name known to all
Send a message via AIM to BobC
Most auto parts stores can help you with a 12 volt light. or you can try this Link.
http://awdirect.com/
FIRST Robotics is like NASCAR for Geeks.
1999 National Champions
Unread 13-11-2006, 18:27
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
Be careful when you buy the types of lights because i know i have some that dont rotate but have 2 lights that are on top of each other and switch back and forth. If you wire it up wrong it doesnt do any damage but it wont switch i will just have both lights on at the same time.
MechWarriors 573
How do you hook up the camera? SpeakerSilenced Programming 18 16-02-2005 15:00
pic: West Covina Police Robot CD47-Bot Extra Discussion 3 28-05-2004 14:41
How do u hook up the digital input to the sensor's wires Fares Technical Discussion 2 14-02-2003 16:41
Lights on our robot (in addition to the rotating light)... archiver 2001 1 24-06-2002 01:02
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
