Go to Post Part of the magic of FIRST is the interaction between different teams- and that becomes clear as day as the clock starts ticking. - mhayon [more]
Unread 13-11-2006, 21:27
REVving up for a new season
FRC #2848 (All-sparks)
Re: using an old p-basic controller
The electronics are the same in the way they are hooked up, if you follow the current wiring diagram you will be fine.
the old code base code is available here. http://www.ifirobotics.com/first-legacy.shtml
you want the section from 2001-2003
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Visual Basic. Using a loop to solve the cosine function. sanddrag Programming 2 10-03-2006 11:45
BASIC operator interface and robot controller John Gutmann Electrical 2 26-04-2005 21:45
the old P BASIC program Thadanator Programming 2 07-04-2005 11:52
Using Old Spike Relays Shark[NH] Electrical 3 13-01-2005 21:49
Is anyone using the BASIC Stamp Preprocessor? Greg Ross Programming 4 12-02-2002 12:24
