Go to Post I believe that FIRST in itself is a reward. - link871 [more]
Unread 14-11-2006, 01:26
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Re: pic: Bag of DeWalts
Originally Posted by Alex469
Now all you need are some variable diameter wheels and you'll be all set for the rest of robotics.
That's really simple, just have pneumatic wheels that you can inflate or deflate using the FIRST pneumatic system.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 15-11-2006, 15:18
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
Originally Posted by Wayne C.
Prior to the 05 season we buillt a protochassis with Dewalts on each of 4 wheels. When tested against our 2003 gearbox in a pushing contest they over-strained and popped out the breakers consistently. Likewise we ran the robot into a wall and found they popped out easily when the robot was forced to stall.
I'm confused here. Do you mean that the circuit breakers kept tripping (and presumably resetting) or do you mean that the DeWalt popped out of gear into neutral?
Were these 'bots ('03 and prototype) geared to have the same gear ratio (ie. the same 'bot speed at the same motor RPM)?
-Mr. Van
Coach, RoboDox 599
Unread 15-11-2006, 22:38
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
-Mr. Van
Coach, RoboDox 599
The circuit breakers tripped. In most of the gearboxes you can usually make a wedge or something to prevent the shifting (at least the manual means).
The 03 bot was geared to be a little faster but we hoped that we could use the Dewalts as a replacement with little loss of speed. Instead of making a sophisticated gearbox and adding the Dewalts to it we hoped to bypass the need for two nested gearboxes. After all, why would we want to add them if we were building a gearbox anyway? (no need to reply) The Dewalts simply didnt function to our requirements.
For many teams these might be the answer to their needs. It depends on how hard you press them.
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 16-11-2006, 20:29
nparikh's Avatar
nparikh nparikh is offline
i heart infrared
AKA: Neil Parikh
nparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond reputenparikh has a reputation beyond repute
Send a message via AIM to nparikh Send a message via MSN to nparikh
WC
Steve + Corey = a new wave in design to figure out how to keep them from breaking our robots. But like someone said..variable wheel size isn't a bad idea
Doing the right thing is always better than doing the easy thing.
Team 25 Alumnus
Attending: NJ Regional, Boston Regional, the Championship Event
pic: River Rage 9 pic JohnBoucher Extra Discussion 2 30-10-2005 14:43
Using a computer to control the pic mikesown Programming 6 13-09-2005 19:13
PIC 18F2431 Sparks333 Programming 9 24-08-2005 01:24
2004 coupler bag boing Kit & Additional Hardware 0 16-01-2004 16:41
