Go to Post I think a 100% student-run team is as good as a school taught by your peers. - [more]
Unread 13-11-2006, 19:50
penguain penguain is offline
AKA: Barry Preston
FRC #1997 (Stag Robotics)
penguain is an unknown quantity at this point
C or C++
which programming language is used in the robot for FIRST(FRC)... i see on the web site it says its C.... but my Team coach said it was C++?
some clarity would be helpful
thanks
Unread 13-11-2006, 19:53
thegathering's Avatar
thegathering thegathering is offline
Angry Troll Lurking in the MUD
AKA: Ben
FRC #1885 (Robocats)
thegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to beholdthegathering is a splendid one to behold
Send a message via AIM to thegathering
Re: C or C++
We use C with an IDE called MPLab by Microchip.
*edit* I wish we could use C++ though, then maybe we'd get some more programmers on our team. C tends to scare them off. (maybe that's MPLab's icky-sticky interface rather than the language itself )
*2006 Champion Rookie All Star Award.
*2 x 2006 Regional Rookie All Star Awards.
Unread 13-11-2006, 20:11
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: C or C++
Its C.
They could always command line compile it. Im sure they would hate that even more.
Unread 13-11-2006, 20:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: C or C++
I don't think an FRC robot program is likely to benefit from object oriented programming in most cases. We're typically not dealing with a lot of objects that need to be created and destroyed that would benefit from a general class, mainly. There would be some benefit from the probable increase in code modularity and code reuse.
Mostly, however, I think objects inherently incur higher overhead costs than simple structures and procedure calls, what with instantiation and all sorts of things. So I don't think you could take advantage of the strengths of object oriented programming without making your code uselessly large.
Unread 13-11-2006, 21:07
AKA: Ben
Re: C or C++
Well, we tried to make our code as object oriented as we could, which ended up working well for our automatically aiming camera/launcher code.
Unread 13-11-2006, 21:46
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Re: C or C++
The icky interface scared me for a bit. C is an awesome language for embedded systems.
My Blog!
Unread 13-11-2006, 21:53
foote stepped in
AKA: E. Foote
FRC #0868
Re: C or C++
just be thankful you don't have to program it in assembly...
C works terrific for a robots needs, when I'm trying to help the java peoples learn it, i tell them
"object oriented programming with robots would be kinda useless. For example, what would be the point in
Robot868 robot1 = new Robot868(void);
robot1.drive(10.0);
when you could write code that would simply be drive(10.0)? besides, the interface that Kevin supplies us with is alot more useful."
Too bad its not so easy to describe #define, or any other preprocessors to them .
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 14-11-2006, 00:21
Re: C or C++
It wasn't C++ code, though, so you didn't have class definitions and a memory manager floating about cluttering things up. You can, of course, still mostly apply object oriented design rules to get more modular, more portable code, but it still won't be C++ code, for good or ill. (Mostly for good)
Unread 14-11-2006, 02:35
Back after 4 years off
FRC #5279
Re: C or C++
Use eclipse, it is much nicer than MPLAB
Also I think C is the easier of the two languages, the things that c++ simplified (Classes Structs etc) are really not important for what we are doing.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 14-11-2006, 06:52
RoboMadi's Avatar
RoboMadi RoboMadi is offline
3 Fs..... Fun Friends FIRST!!
AKA: Imad
FRC #0612
RoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant futureRoboMadi has a brilliant future
Re: C or C++
Last year, one of our programmers was used to Eclipse, and he pretty much hooked up everyone to use it. Its really nice, especially the way it breaks down the code.
C or C++, as far as writing the code, theres not much of a difference. I'm just waiting when FIRST will upgrade their systems, and we'll have some other language to play with...
But on a bright note, responsive time for C is much faster than any other language.
Unread 14-11-2006, 08:24
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Re: C or C++
I hope this never happens. C is a de facto standard in embedded software. In FIRST a good application of C++ is creating a dashboard program.
Unread 14-11-2006, 10:31
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
Re: C or C++
I personaly would like to see a move to C++ . .mainly because I think its easier to think of a robot in terms of objects than not. and for the most part any thing you write in C can be put directly in to C++ with out any changes.
not saying that we take the jump all the way to java, (java.eguals(the.suck())) , but saying that a move to OO would be nice.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 14-11-2006, 14:25
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
Re: C or C++
C++ would be a pretty hefty extra load on the processor, and for minimal gain. As far as objects go, I've found structs are pretty good, I'm working in my spare time on an object based robot API using all structs, its very doable.
Last year I used very modular code utilizing the same method, well enough I could pick up and move parts of my code in to another teams to help them, with the only change being adding the interface code to theirs. Once they had it, we were able to "plug" code modules in, it was very effective.
Matt Krass
Unread 14-11-2006, 16:47
♥♣♠♪'s Avatar
♥♣♠♪ ♥♣♠♪ is offline
DemiOmniGod
FRC #1546 (Chaos Inc.)
♥♣♠♪ will become famous soon enough
Re: C or C++
All you have to do is explain what compilation is and everything else should be easy.
Programming && English !mix
Our website
Unread 14-11-2006, 21:00
Umm Errr...
Re: C or C++
I think most of us would agree that we would rather have the flexibility and added features of C++, particularly object oriented-ness.
The problem with C++ is that along with its added features comes added bloat and inefficiency. Unless the architecture and processing power were SUBSTANTIALLY and unnecessarily upgraded, all of the people who keep complaining that C is primitive would be complaining that their code wouldn't run if we upgraded to C++. Memory allocation/deallocation is no small task, especially when handled in software. C++ is good for PCs where functionality is a greater priority over efficiency and there is an abundance of computational power, but not so great for our application. In industry, C is not considered outdated, it is the standard in the world of embedded programming and for good reason. C is sleek and slim.
Heated seats, radios and air conditioning are good to have but race cars don't have them and do just fine without them. Our robots, like race cars are designed minimalistically. There is nothing on a FIRST robot that is not absolutely necessary and that goes for code too.
Any problem that can be solved in C++ can be solved in C. The solution may not be as coder friendly, but chances are it will be smaller and take fewer processor cycles to execute.
1139 Alumni
