Go to Post Remember, the song is FIRST and the competition. We are the group. We dance to FIRST, we move because of it. - Joe Matt [more]
Unread 15-11-2006, 10:44
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
pic: Colson Wheel and Sporcket.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 15-11-2006, 10:45
Billfred's Avatar
Billfred Billfred is offline
Re: pic: Colson Wheel and Sporcket.
I'm looking at the wheel, and I'm wondering two things:
1) What exactly got shaved off with the paint can opener?
2) How'd you get the bolt circle done?
Unread 15-11-2006, 10:52
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
We used "colson-esqe" wheels on our '06 bot. We purchased the NPC Brand from robot marketplace. The NPC brand have a pre-insalled hub (I want to say made of delrin) that is already keyed. So instead of having just the wheel spin, the entire shaft did.
My question is how well does your version work?
Unread 15-11-2006, 11:54
Gabe's Avatar
1. A paint can opener has a hooked end, so I sharpened this on a grinding wheel until the edge was like a chisel (think of a paint scraper). Then I mounted the wheel on a bolt and spun it in a drill press and, using the sharpened scraper, started shaving away.
2. For the bolt holes I went online and printed a full size drawing of the kit sprocket, which I glued to the aluminum to show me where I had to cut and file, including where to drill the bolt hole. I used the same method to align the bolt holes on the wheel.
[EDIT]Sorry, Billfred. Misread your first question, but Greg answered it below.[/EDIT]
Unread 15-11-2006, 13:56
REVving up for a new season
FRC #2848 (All-sparks)
The colson wheels have a round sidewall, i suspedct the used the scraper like a lathe and flattened out the side wall.
I have used this method before to drill holes, I just would like to issue a warning to people considering doing this. You need to make sure you have a center mark on the holes, then center punch them. Using just the exterior of the hole to line them up can cause issues with proper spacing. Otherwise this is a good solution/use of cad for teams without CNC or machine tools to build parts, It works especially well for sheet metal whole locations and anything that has a flat surface. It can also be used to make cut lines on parts.
I have used colson wheels before for other applications and they are very durable, but the major advantage comes from the weight and price of these wheels, the tread is 65A durometer, similar to the wheel chair wheels.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Colson Wheels sanddrag Technical Discussion 11 22-03-2006 10:02
Algorithim question: 4 wheel steering and power Validius Programming 2 15-11-2005 17:41
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
wheel hub kit and sprocket archiver 2001 7 23-06-2002 23:27
