Go to Post Thanks to everyone who made the regional possible - I know my team had a blast and I'm pretty sure most other teams did too. - Steve Howland [more]
Unread 14-11-2006, 22:43
Re: C or C++
Originally Posted by Rickertsen2
I think most of us would agree that we would rather have the flexibility and added features of C++, particularly object oriented-ness.
Why? What particular itch would be scratched by having OO in your robot-programming toolkit?
Any problem that can be solved in C++ can be solved in C.
That's obviously true -- because the first implementation of a C++ compiler was as a preprocessor that produced straight C code. If you want to use C++ to program your robot, just get a copy of the old AT&T Cfront program.
Unread 14-11-2006, 23:09
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: C or C++
Well it would let you use << instead of printf's. Heck you could overload << operator to output motor values or set the target of a PID loop or other mostly useless but amusing things, I suppose.
Unread 14-11-2006, 23:17
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: C or C++
It's amazing the misconceptions that have been posted here about the differences between C and C++. C++ code doesn't have to be bloated compared to equivalent C code. When using the advanced features you do have to know what you're doing if you don't want to pay a size or performance penalty.
I used C for years and then moved to C++. Moving back to C was an extreme shock. Having to jump through hoops to do reasonable encapsulation and using funky naming conventions to keep the code organized and readable is a roaring pain. The lack of proper const types is inhibiting.
Some here seem to think that using C++ entails a lot of new and free calls to create and destroy objects. If your C code isn't using a lot of malloc and free calls, there will be no difference. And for a FIRST robot you really don't need any dynamic memory allocation.
C++ is a much better language and with proper use can even produce smaller, faster code than C. Not to mention if the code is properly written, it's easier to understand, maintain, and more robust.
Unread 15-11-2006, 08:13
Gdeaver Gdeaver is offline
FRC #1640
Re: C or C++
I always thought the problem with object oriented languages and microcontrolers was the async nature of OO. In other words OO is terrible for RTOS's.
Unread 15-11-2006, 08:21
Re: C or C++
I was asking about Object Oriented, not Operator Overloading. My question is this: how would object-oriented programming be useful in programming a FIRST robot?
Modular programming is obviously a good thing, but I don't really see a good use for classes and inheritance and polymorphism and such.
Unread 15-11-2006, 08:30
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: C or C++
Actually C++ is quickly gaining in popularity in the embedded world. The last project I worked on at Motorola was almost entirely C++ code running on an embedded control board under the pSOS and OSE RTOSes.
Unread 15-11-2006, 10:09
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: C or C++
Originally Posted by efoote868
Too bad its not so easy to describe #define, or any other preprocessors to them .
For #define, I told the kids on my team it is essentially the same as a find-replace on your code before it actually gets compiled. That explanation is good enough for what we used it for (#define leftMotor1 pwm01).
Unread 15-11-2006, 12:48
AKA: Tim Craig
Re: C or C++
Object oriented languages aren't any more asynchronous than purely procedural languages. If you're talking about the message passing paradigm, that's just OO speak for function calls.
That said, however, most microcontroller programs have to deal with asynchronous events.
Unread 15-11-2006, 15:40
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: C or C++
http://www.virginiafirst.org/workshop_info.shtml
I figure it just a typo but look at "Beginning Programming - part 1". Maybe they know something we dont know. Im pretty sure its a typo though.
Unread 15-11-2006, 15:46
X-Istence X-Istence is offline
Melt the RC controller!
AKA: Bert JW Regeer
X-Istence will become famous soon enoughX-Istence will become famous soon enough
Send a message via AIM to X-Istence Send a message via MSN to X-Istence
Re: C or C++
I screw it all. Let's go back to the PBASIC boards from a few years ago.
My Blog!
Unread 15-11-2006, 18:47
Team 2021 Captain
AKA: Chris Davidson
Re: C or C++
LOL. I have never used to PBASIC boards but I like the C ones just fine.
Unread 15-11-2006, 21:34
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: C or C++
I'm going to try to clarify somethings about using OOP on the current breed of controllers.
Using any kind of memory management on the PIC18s would incur a performance penalty in terms of pointers, indirect addressing, management overhead, etc. I don't care how few malloc()/free() calls there are; it only takes one. In order to perform indirect addressing, you have to copy the pointer to a special register. Every dereference requires this, on a byte-by-byte basis. I'm not even sure you can perform an indirect function call. (Remember, code is stored seperate from data.)
I agree that using OOP principles is a Good Thing(tm). But the limits of the PIC18 processors are such that full-blown OOP (or even just objects) as it is normally implemented is impractical.
