Go to Post Honestly though, having a cave would be one of the greatest places to build a robot. There's already lack of light and lots of floor space! Well, if you have a good cave sponsor, that is. - Bryce Clegg [more]
Unread 15-11-2006, 21:34
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: C or C++
I'm going to try to clarify somethings about using OOP on the current breed of controllers.
Using any kind of memory management on the PIC18s would incur a performance penalty in terms of pointers, indirect addressing, management overhead, etc. I don't care how few malloc()/free() calls there are; it only takes one. In order to perform indirect addressing, you have to copy the pointer to a special register. Every dereference requires this, on a byte-by-byte basis. I'm not even sure you can perform an indirect function call. (Remember, code is stored seperate from data.)
I agree that using OOP principles is a Good Thing(tm). But the limits of the PIC18 processors are such that full-blown OOP (or even just objects) as it is normally implemented is impractical.
