Go to Post You don't need to prototype everything, just the stuff you want to work. - JVN [more]
Unread 17-11-2006, 21:15
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
Easy C programming Problem
Hey,
Ok, so we have the programming kit and easy c version 2.8.1. We installed everything and downloaded pretty much everything we could from vexlabs. However, for some reason, we get an error saying "There were linking errors! see output window for details". I looked up linking errors, but it didnt seem to fit our situation, we were only trying outthe default coding.
I then checked out the IFI loader, and found that it could not detect the compiler =\. I am totally confused.
Could it be, that we did not install easy c version 1.1?
Appreciate the help
Fred
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
Unread 17-11-2006, 21:28
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Re: Easy C programming Problem
Originally Posted by fredliu168
Hey,
Appreciate the help
Fred
What did the output window say?
http://www.mikesorrenti.com/
Unread 18-11-2006, 21:15
fredliu168's Avatar
it doesnt say anything...
In 2006
In 2007
Events:
Unread 18-11-2006, 21:21
fredliu168's Avatar
I am very very worried that this is because we only installed version 2.8.1 and not version 1.1.
Can anyone tell me if that is the problem, because then I would need to get a version 1.1 CD and it takes a very long time to ship it to Canada...
In 2006
In 2007
Events:
Unread 18-11-2006, 22:20
Daisy Daisy is offline
AKA: my real name
FRC #0173 (RAGE)
Daisy has a brilliant futureDaisy has a brilliant futureDaisy has a brilliant futureDaisy has a brilliant futureDaisy has a brilliant futureDaisy has a brilliant futureDaisy has a brilliant futureDaisy has a brilliant futureDaisy has a brilliant futureDaisy has a brilliant futureDaisy has a brilliant future
You may want to try PMing Adam. He is one of the guys behind the EasyC concept, and very good at explaining things.
Daisy
Unread 19-11-2006, 10:28
Dan Larochelle Dan Larochelle is offline
FRC #0040 (Pioneers)
Rookie Year: 1993
Dan Larochelle has a spectacular aura aboutDan Larochelle has a spectacular aura about
easyC V2.8.0.1 does not require V1.1 to be installed. V2.8.0.1 is the current version shipping with all the programming modules.
There are a couple of things you can do:
Open a new project and select the Compile Project icon. You should get a message "The project was compiled successfully". Do you still get linking errors?
If you still have linking errors, try reinstalling the software. Maybe the compiler did not install correctly.
If you downloaded the install, try downloading it again. Maybe the download was corrupted?
Check out the Getting Started section of the easyC help file. The are several steps you can walk through to test easyC and the programming module. This will help pinpoint the problem.
If you are still having trouble, email us support@intelitek.com.
Thanks
Unread 19-11-2006, 22:44
fredliu168's Avatar
Thank you so much, IT WORKS!!!!
Lol it seems that our other labtop doesnt work(could it be because its korean?), so we just bought a new one. Thanks for your help.
In 2006
In 2007
Events:
Easy C, loader problem gabrielse Programming 13 02-02-2006 07:44
Easy C programming , Worth teaching? Nine9cracker Programming 16 19-01-2006 00:45
Easy-C Programming CD Jeff K. Programming 2 09-01-2006 02:20
What do you think about how easy theyre making programming? Leav Programming 76 11-01-2005 12:07
programming problem gthakore Programming 16 20-04-2002 12:21
