Go to Post You know FIRST is on the level of sports when you can give predictions like sports casters do. :) - RoboMaster [more]
Unread 19-11-2006, 12:03
Joe_Widen's Avatar
Joe_Widen Joe_Widen is offline
FRC #1675 (The Ultimate Protection Squad)
Joe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud ofJoe_Widen has much to be proud of
Question on v-belts
Ok, so I'm designing a cvt. I've tried searching everywhere and I can't find the full specs of a vbelt. McMaster only gave me the width at the top and the height. Anyone know how to figure out the width of the bottom, or the angle of the sides of the vbelt?
Finally in college =]
2009 Midwest Regional Champions - Thanks 111 and 1625
Unread 19-11-2006, 12:15
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Question on v-belts
I'd start somewhere like the Gates web page
Unread 19-11-2006, 12:17
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
See here. Also, Machinery's Handbook has several pages dealing with this (Machine Elements -> Flexible Belts and Sheaves).
Unread 19-11-2006, 14:12
colin340 colin340 is offline
human
AKA: Colin Nobles
FRC #0148
colin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond reputecolin340 has a reputation beyond repute
Send a message via AIM to colin340
i would check your local snowmobiles dealer they should have many size of cvt belting since as most snowmobiles use i cvt thing
61 77 77 20 77 69 74 74 6c 65 20 62 61 62 79 20 63 6f 6e 64 6f 72 20 69 73 20 72 65 61 64 69 6e 67 20 43 44
Unread 19-11-2006, 17:17
Joe_Widen's Avatar
Thanks for the help everyone. As of right now, I'm designing the cvt. I've looked through those websites and could find what I was asking for. Ill try to be a little more clear. I need to know the bottom the width and the side angles of the V-Belts. I can find the top width and height. Is there an easy way to figure the bottom width and side angles out, like a general formula?
Unread 19-11-2006, 18:44
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Ahh the good 'ole Variable Diameter Pulley CVT. We're also working on one, but probably not for this coming season. For V belts, they are usually around 24-29 degrees for snowmobiles, and a lil' trig can help you calculate the base. You should also use pulleys that are around 24-29 degrees for being upshifting and squeezing of the pulleys. The actual degrees of the wall of the pulleys and the type of pulleys you are going to use need to work with the weights. Pretty much everything needs to work together. Sorry if that was confusing, I only had 2 hours of sleep.
Unread 19-11-2006, 18:48
MrForbes's Avatar
AKA: Jim
according to Mark's handbook....the pulley angle varies from 30 to 38 degrees, depending on belt width and pulley diameter.
Ordering Belts =Martin=Taylor= Technical Discussion 4 19-09-2006 21:32
Belts in Inventor Hunter Levesque Inventor 7 22-04-2006 10:11
Conveyor belts Max Lobovsky Technical Discussion 4 12-01-2006 19:32
Belts, Timing Belts, and Automobiles. Anton Abaya Technical Discussion 5 09-01-2002 19:21
Conveyor Belts Pengiun Joe Off-Season Events 2 02-11-2001 22:49
