Go to Post Don't just build a robot; build up your community. - Pat Arnold [more]
Go Back   Chief Delphi > Competition > Championship Event
Unread 19-11-2006, 12:46
BBnum3's Avatar
BBnum3 BBnum3 is offline
Ridiculously proud of MN First
AKA: Nat Thompson
FRC #1816 (The Green Machine)
BBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to beholdBBnum3 is a splendid one to behold
Send a message via AIM to BBnum3
Number of Matches at the Championship
First, I must say that the Championship was absolutely amazing last year. The experience was great, the tournament and just the atmosphere were all really exciting.
There's one small issue I feel needs to be addressed, and that is the amount of matches teams play. Last year it was 7 per team, and I think it should be a lot more, because more matches means more accurate seeding. Teams would often be seeded inaccurately. I'll use 217 as an example. They were seeded 17th in Archimedes, and were clearly not the 17th best robot in the division. Now they did end up winning the Championship, so this is not to say that good robots don't get rewarded. I want to know what ideas people have for increasing the number of matches at the Championship. I know the logistics are crazy with so many teams at the event, but there's got to be some way to get more matches in.
An obvious solution would be to increase the number of fields. I can't picture exactly in my head the dimensions of the Georgia Dome, but it seems like two more fields could be squeezed in. Put Da Vinci and Einstein down at one end of the field, and have the six FRC fields condensed a little bit.
Any ideas?
(I know there has been some discussion on related topics here and here but I felt that this needed its own thread.)
Founding member of Team 1816.
Unread 19-11-2006, 12:55
Allison K's Avatar
Allison K Allison K is offline
AKA: Allison Kneisler
FRC #3538 (Avondale RoboJackets)
Allison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond reputeAllison K has a reputation beyond repute
Re: Number of Matches at the Championship
I know I've posted this somewhere else as well (I just can't find it), but instead of adding two more divisions, I think you could increase the number of matches per team by putting two fields in each division. One field could be running reset and having the robots get all set up while the other field is running a match. There's 9 regionals in North America in weeks 3 and 5 so there should be enough fields. With reduced set-up time you should be able to fit in more matches without having to worry about extra volunteers and crossover between the radios.
There's still the issue of space on the dome floor but if you only add a field without the need for any additional screen, equipment, queuing space, etc. it seems like it would be possible
~Allison
FRC3538 : RoboJackets : 2014-??? : Head Coach & Drive Coach
FRC226 : Hammerheads : 2003-2013 : Strategist
Unread 19-11-2006, 13:18
Billfred's Avatar
Billfred Billfred is offline
Honestly, I don't think that you can add that many more matches.
Let's just ignore the Dome's requirements and consider this on just the basis of running fields. Each field requires six radio channels, and runs on a six-minute match cycle. (In other words, we have six robot-matches completed every six minutes.)
The IFI radio modem has forty channels. Six of them can be accessed by teams, which leaves the possibility that someone will make a dumb mistake and run off the field on a radio and lock up a competing robot. Clearly, this prospect is unacceptable. Therefore, we have 34 channels available to us. That breaks down to five fields of 3v3, or eight if FIRST reverted to 2v2. (We'll ignore 2v2; FIRST's current-generation field barrier is made for 3v3, no matter how Mission Mayhem rigged it up, and should be used by past experience through the 2009 season.) So yes, FIRST could run a fifth FRC field in Atlanta. Now how do you incorporate that into the elimination bracket on Einstein in a manner that is both fair and easily understood by the average person on the street? I don't think you can.
Allison made an interesting idea with giving each division the GTR treatment, but I believe a similar radio problem would happen here. You'd have to run both fields on the same channels, for the same reasons as above, which would mean that if any robot or OI was turned on on the inactive field, they'd be transmitting on the same channel as the competing robot. I haven't tried it when it's just an OI or RC, but I have empirical evidence to prove what happens when you have more than one robot connected and attempting to communicate on the same channel.
Since we can't really add more fields to the Championship, we've got to get in more robot-matches through some other means.
We could decrease the match cycle time, either by a shorter match or a shortened inter-match period. Shorter matches aren't as interesting--two minutes flies by as it is. Shorter intermatch periods mean both the teams and the field crew have to be absolutely on top of things. That six minutes involves running the match, having the refs score it, field reset doing its thing, any field issues being repaired, teams moving their robots off, the new robots coming on, getting set up, and ready (including a once-over by the IFI rep). If anything goes wrong, matches get delayed and go later than planned. Especially on Saturday, this is unacceptable as well.
This leaves the final option of lengthening the Championship. This involves either starting earlier or finishing later, both of which cost more, both in venue fees and personnel costs. (Don't ignore the cost of volunteers--food, T-shirts, credentials, and the oh-so-spiffy volunteer pins all cost money. Less than paying them, but it still costs money.) The other problem is that you get burnout here--volunteers get more exhausted, and some have long drives ahead of them that evening. Getting a crew to stay even longer when they have enough trouble staffing at the current level will require some solution I'm not equipped to produce. (I'm marketing, not management.)
It's a complex problem, one that would be interesting for any management science folks out there. But I really can't see a solution to it.
Unread 19-11-2006, 13:32
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Hypothetically, they could set it up like the 2001 Championship, with additional fields with limited-capacity, portable bleachers in another location. Surely there are additional exhibition halls in the GWCC complex which could accomodate that.
If you keep enough distance (and concrete/steel) between the conflicting transmitters, you might be able to get away with it.
You'd also want to make sure that every team was playing some matches on the Georgia Dome fields, as well as some in the basement.
But there's another concern here: at a lot of regionals, the transit time between pits and field is miniscule. At Waterloo, for example, it's less than a minute. At the Championship, it's often much longer. Then, there's the time spent in-queue. That means that you've got less time to work on the robot between matches, and means that it is rather more difficult to keep everything running smoothly, from a team's perspective. Some teams may actually welcome the fact that they're not quite so rushed.
Unread 19-11-2006, 14:10
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Even if the difficulties could be overcome, I'm not convinced that more matches at the Championship would be a good thing.
Scouting is, and IMHO should be, as important as seeding. I don't think more matches will make selecting alliance partners, or promoting your team to be selected, any easier.
Richard Wallace
since 2003
Unread 20-11-2006, 13:18
Mike Starke Mike Starke is offline
FRCTop25.com
Mike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond reputeMike Starke has a reputation beyond repute
Believe me, I am in favor of having more matches... one or two bad matches can put your team out of the top 20.
Being on drive team, it seems like your always on the move. If there were more matches with the same number of fields, that would be crazy. If there was a way to both have the pits closer to the field, and a way to have more fields, then I think the idea of more matches could be plausible.
However, by the time Nats roll around, there has been plenty of time to research and scout the teams that will be there. Regional winners have been announced, and Divisions have been released.
This is when the most scouting should occur- between regionals and Nats. You have time to research robots, and see what teams are going to be good in your division. You should already be going into Nats knowing what teams you either want to pick, or teams you want to get picked by. However, this doesn't mean that you should be closed minded. There are always teams that you don't expect it to make it, but do. And those usually are the best ones. (Just because I'm on 340, and its fresh in my mind, look at 2004, with 1126, 67, and 340 in Newton. Nobody expected that to happen, with having at least one team out of the top 20.)
So, this is just my insight, and thoughts...
Unread 20-11-2006, 13:48
Dan Richardson's Avatar
Dan Richardson Dan Richardson is offline
iR3 Creative
AKA: Dan Richardson
Dan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond reputeDan Richardson has a reputation beyond repute
More matches would be all fine and dandy but remember if your team is not ready to perform that may say just as much as the ranking system.
If you lose one game in the NCAA tournament your out of national championshipo contention. It also very similar with the BCS in college football.
In FIRST at the Championships marketing, and scouting is all that evens the playing field. If not for these 2 then a lot of the best teams in the nation could potentially never get their chance.
If you expect it to be a championship its going to be tough, and adding more games may really not be the solution.
CO-Founder of Robot in 3 Days and the Robot in 3 Day Challenge.
Unread 20-11-2006, 15:08
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
I think that more matches could be possible. Thursday is used for practice right, well you have already been to 2 or 3 regionals on your machine and some have a practice bot. Since the championships are earlier this year and there is not a big layoff, you could make it to where everyone gets one practice round which is 2 matches of practice which should be enough. you start the qualifying round around 1 on thursday and that will allow each team to get at least 2 or 3 more matches in, plus what they get on friday and saturday. This will allow for at least 10 matches and not even interfere with all of the money and extra day it would take for the venue or the teams to take out of thier pockets. It is a reasonable thought.
-Josh Murphy-
Unread 20-11-2006, 15:26
Let me just point out one of many logistical issues that would arise, if that were to be implemented. You'd need to rearrange inspections. Last year, with our crew of inspectors, we were working hard all day Thursday, and a bit on Friday morning. So you'd either need many more inspectors (roughly 2 to 2.5 times as many, I'd estimate) and a few more scales and sizing boxes, or you'd need to open the pits for inspections on Wednesday afternoon (after the uncrating) and convince teams to get their inspections done at that point.
Unread 20-11-2006, 15:45
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Maybe Im looking at this differently, but to me the point of adding more matches isn't to make it more fair for everyone else. It's to make sure the top 8 are as close to the best 8 robots in the division as possible.
For example, look at Archimedies in 2005. That division was absolutely loaded. Yet a bunch of powerhouse teams ended up seeded super low, and a bunch of weaker teams ended up seeding high, because there aren't enough matches to eliminate luck influencing the standings.
I think we should add more matches not to help teams that have bad luck and lose a match or two, but to push the ones that performed extremely well to the top, rather than have teams that had good partners and didnt play anyone tough end up above teams that dominated their competition, but got pitted against each other and lost a match.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-01-2007, 17:36
Nawaid Ladak's Avatar
Nawaid Ladak Nawaid Ladak is offline
The Banana People Are Awsome!
AKA: Nawaid Ladak
FRC #0945 (Team Banana)
Team Role: Tactician
Nawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant futureNawaid Ladak has a brilliant future
Send a message via AIM to Nawaid Ladak Send a message via MSN to Nawaid Ladak Send a message via Yahoo to Nawaid Ladak
a GTR Field setup would work fine, and maybe extending the times on friday would work...
for example
opening ceremonies start at 8am, events begin at 9am, and SHOULD end at about 5.
maybe extend that to 7 or 8pm, with six minute periods. that means 20-30 more matches.
start it back up at 0 on Saturday, as usual
alliance parings are at 12pm instead of 11:45am
have 12 teams in the eliminations.
and the event would end at 8, perfect time slot on ESPN or ESPN2 in mid april on a Saturday afternoon. what else could be on..... world series of poker?????
lol, but yea, this is probably the best idea.
maybe extend the radio channel availability list or natioals
"When you make a mistake, admit it, correct it, and learn from it - immediately."-Stephen Covey
I can still learn from this quote, how about you?
Nawaid Ladak
2003-2006 FRC # 1402: Freedom Force. Scouting
2007 FRC # 1694: RoboWarriors. Mentor
2008-Present FRC # 945: Team Banana. Mentor
Contact me
E-mail: LadakN (at) GMail (dot) com
Twitter / Facebook / Youtube
Unread 19-11-2006, 15:55
Pat Fairbank's Avatar
Pat Fairbank Pat Fairbank is offline
Circuit Breaker
Pat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond reputePat Fairbank has a reputation beyond repute
Send a message via MSN to Pat Fairbank
I disagree with your assessment that seven matches are not enough for accurate seeding at the Championship.
For those teams who perform consistently at the same level, seven matches are plenty to accurately determine their ranking. For teams who don't perform consistently due to periodic mechanical breakdowns or driver inexperience or lack of testing time, perhaps seven are not enough to allow them to "find their groove". But at the Championships, the pinnacle of the FIRST competition season, it only makes sense that the teams that can perform consistently well by that point should be rewarded accordingly in the rankings, as opposed to holding more matches as an equalizer. There are five tough levels of elimination rounds to get through in order to win the Championship, and for a team prone to inconsistent performance, that's a lot of time in which something could go wrong.
That's not to say that teams who performed inconsistently in the qualifiers can't perform well in the eliminations, and that's where scouting becomes tantamount to seeding, as Richard said.
As far as the example of team 217 is concerned, the ThunderChickens deserved a seeding of 17th or thereabouts, as they were having trouble with their shooter and their autonomous mode throughout the qualification rounds. In the eyes of scouting teams, to choose them would be a bit risky as compared to some of the more consistent performers in Archimedes. But luckily for both our teams, after the conclusion of the qualifiers 217's personnel were successful in convincing 296's scouts that the bugs had been ironed out and that they were once again shooting 10 for 10 in autonomous.
Patrick Fairbank
Team 254 | Mentor (2012-)
Team 1503 | Mentor (2007-2011)
Team 296 | Alumnus (2001-2004) | Mentor (2005-2006)
patfairbank.com
Unread 19-11-2006, 16:02
BBnum3's Avatar
AKA: Nat Thompson
That makes a lot of sense to me now. Although seven matches may not be optimal, I think you are right that seven does a good job. Robots do need to perform consistently, and my team's was an example of that. Our robot was not nearly as advanced as a lot of other teams, but we made 10/10 in the lower goal in every single autonomous and ended up with the sixth seed. Regardless of seeding, the best and most consistent teams will prevail in eliminations.
Unread 19-11-2006, 17:06
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
I don't entirely agree with this. Due to alliance partners, there are factors which teams can't control. Regardless of how good your robot is, a 1v3 match is next to impossible to win. I know for a fact that our robot consistently malfunctioned to the point where most of our alliance partners were playing 2v3 matches at best. If you have more matches, those sorts of factors even themselves out, and the robots who are the best do end up on top.
If you have fewer matches, such as the 7 at championships, one or two matches with malfunctioning or no-show alliance partners can mean the difference between a top 8 seed and the middle of the pack, regardless of how perfectly your own robot preformed.
This does again reinforce the importance of scouting. There is no reason such a robot should not be picked for eliminations, but given the limited number of matches, they would probably end up lower ranked that they might deserve.
That said, I don't see any resonable way to increase the number of matches at championships short of making in longer.
Unread 19-11-2006, 22:38
foote stepped in
AKA: E. Foote
FRC #0868
in response to the 9 matches at a time, i think you're forgetting the practice fields. (they don't use as much stuff, but its still a field, and 5 fields for competition, 4 fields for practice, right?)
I'd like to see einstein's field be used, instead of just blank for the entire time. Also there could be another field squeezed in... which leaves an interesting idea... Wildcard matches. Teams would be randomly (er... yeah) picked to play against each other, from all divisions. These would be played on the new field and on einstein. That would be pretty fun.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Videos of the matches at NJ tchescow Regional Competitions 4 09-03-2004 13:07
Need the number for the Norgren Pressure relief valve Jack21 Pneumatics 0 23-01-2004 16:32
As the matches Begin Boilerman31 General Forum 3 07-03-2003 12:19
before the matches Stephen Kowski Rules/Strategy 3 01-02-2002 08:45
3 is the number and the number shall be 3... Joe Johnson General Forum 21 03-12-2001 17:08
