Go to Post I love pushing buttons!!! - Michelle Celio [more]
  #31   Spotlight this post!
Unread 16-11-2006, 22:27
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
Re: FusionEdit v0.1
You may want to upload this to FIRST Software Repository when it is all finished.
  #32   Spotlight this post!
Unread 17-11-2006, 18:42
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: FusionEdit v0.1
Originally Posted by shawger
Why not just make it available for download? A lot less work for you, and just as convenient for all of us
I thought I might save teams (and the servers) the 100~150MB download. And by putting it in the kit, teams are more likely to use it.
  #33   Spotlight this post!
Unread 17-11-2006, 21:01
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: FusionEdit v0.1
Originally Posted by Astronouth7303
I was thinking of coming up with such a package and sending one to every team. (Too late for the KOP?)
The thing is i dont think it would get used by to many teams. However if we made a Live CD with all the files we needed then that would be perfect. Boot the CD, load your code from a USB drive, write, compile, load onto robot, save the code, log off. The end. And it would work nice and smooth. I have worked alot with Slax, a live cd based off of Slackware. If someone is interested maybe ill start that project.
  #34   Spotlight this post!
Unread 18-11-2006, 00:10
shawger shawger is offline
Programming Subteam Leader
FRC #1732 (Hilltopper Robotics)
shawger will become famous soon enough
Re: FusionEdit v0.1
100MB! I had no idea it was that big. But that still only takes a couple minutes to download, and you can host it for free at a place like Sourceforge.
And if you wanted to put it in the kit, that would require all sorts of approval from the higher-ups, and it would have to work perfectly or near-perfectly, unless you want hundreds of emails/forum posts complaining about how it won't work for whatever reason.
  #35   Spotlight this post!
Unread 18-11-2006, 07:03
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Re: FusionEdit v0.1
Uh... It's only around 1.5MB.
  #36   Spotlight this post!
Unread 18-11-2006, 17:26
Team 2021 Captain
AKA: Chris Davidson
Re: FusionEdit v0.1
I think he is talking about having Eclipse in the kit with pycloader and the eclipse plugin. Eclipse is like 120mb iirc.
  #37   Spotlight this post!
Unread 19-11-2006, 18:46
et1337's Avatar
et1337 et1337 is offline
et1337
AKA: Evan Todd
et1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of lightet1337 is a glorious beacon of light
Re: FusionEdit v0.1
Alright, the SourceForge site is up!
Website: http://fusionedit.sourceforge.net
SourceForge Project site: http://sourceforge.net/projects/fusionedit
There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order.
et1337
  #38   Spotlight this post!
Unread 19-11-2006, 21:50
Re: FusionEdit v0.1
Glad to see you released it under the GPL! I'm trying it now and will let you know what I think.
One small problem - you need to distribute the GPL with the source code.
  #39   Spotlight this post!
Unread 20-11-2006, 18:20
et1337's Avatar
et1337
AKA: Evan Todd
Re: FusionEdit v0.1
Fixed. Thanks for pointing this out.
et1337
  #40   Spotlight this post!
Unread 26-11-2006, 12:32
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: FusionEdit v0.1
So I went to test the program some more, and it wouldn't run.
I went and tried to run it from source so I could find the problem, and I found that when the code tried to find my computers IP it found "::1". I can ping this address, but the software throws an incompatible IP address exception.
Is this a firewall problem?
EDIT: Exception data.
System.Net.Sockets.SocketException was unhandled
Message="An address incompatible with the requested protocol was used"
Source="System"
ErrorCode=10047
NativeErrorCode=10047
StackTrace:
at System.Net.Sockets.Socket.DoBind(EndPoint endPointSnapshot, SocketAddress socketAddress)
at System.Net.Sockets.Socket.Bind(EndPoint localEP)
at FusionEdit.FusionServer.Initialize() in C:\Documents and Settings\Eric Haskins\Desktop\Source\Source\FusionServer.cs:line 59
at FusionEdit.FusionServerForm..ctor(String[] Arguments) in C:\Documents and Settings\Eric Haskins\Desktop\Source\Source\FusionServerForm.cs: line 38
at FusionEdit.StartupForm.ServerButton_Click(Object sender, EventArgs arguments) in C:\Documents and Settings\Eric Haskins\Desktop\Source\Source\StartupForm.cs:line 55
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.O nMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.W ndProc(Message& m)
at System.Windows.Forms.NativeWindow.DebuggableCallba ck(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.SendMessa ge(HandleRef hWnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.Control.SendMessage(Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.Control.ReflectMessageInterna l(IntPtr hWnd, Message& m)
at System.Windows.Forms.Control.WmCommand(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Mes sage& m)
at System.Windows.Forms.ContainerControl.WndProc(Mess age& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.UnsafeNativeMethods.CallWindo wProc(IntPtr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.NativeWindow.DefWndProc(Messa ge& m)
at System.Windows.Forms.Control.DefWndProc(Message& m)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.UnsafeNativeMethods.DispatchM essageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager. System.Windows.Forms.UnsafeNativeMethods.IMsoCompo nentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.Run MessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.Run MessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at FusionEdit.Startup.Main(String[] Arguments) in C:\Documents and Settings\Eric Haskins\Desktop\Source\Source\Startup.cs:line 21
at System.AppDomain.nExecuteAssembly(Assembly assembly, String[] args)
at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
at Microsoft.VisualStudio.HostingProcess.HostProc.Run UsersAssembly()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Eric Haskins KC9JVH
  #41   Spotlight this post!
Unread 26-11-2006, 21:13
AKA: Jamie Bliss
Re: FusionEdit v0.1
Probably not. "::1" is the IPv6 equivalent of 127.0.0.1. The software is most likely expecting a IPv4 address (although I'm surprised it can't handle IPv6 addresses if windows does).
  #42   Spotlight this post!
Unread 26-11-2006, 21:21
AKA: Eric Haskins
Re: FusionEdit v0.1
When I looked at the code I found that I was getting an array of IP addresses, and the code only tried to use the first one. I rewrote the code so if the first one fails then it looks to next, then the next, ect.
The IPv4 vs. IPv6 incompatibility could be the problem, but I know I made it work so its ok for now.
Eric Haskins KC9JVH
