Go to Post Michigan is all about tough love. If you can make it there you can make it anywhere. - Koko Ed [more]
Go Back   Chief Delphi > Other > VEX
Unread 13-11-2006, 14:29
chewy's Avatar
chewy chewy is offline
AKA: Hayon
FRC #1676 (Pascack Pi-Oneers)
chewy is an unknown quantity at this point
VEX Chains
Does anyone know what the amount of strength that a VEX Chain can handle. Like how many pounds of force can it take without breaking a link.
Thanks,
Ethan
Unread 13-11-2006, 21:40
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
Re: VEX Chains
We were wondering that too. Even though it's not important any more I'd like to know too.
Unread 14-11-2006, 20:16
skimoose's Avatar
skimoose skimoose is offline
Parent/Mentor/Engineer
AKA: Arthur Dutra
FRC #0228 (GUS)
Team Role: Electrical
skimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond reputeskimoose has a reputation beyond repute
Re: VEX Chains
We haven't run tests, but we had vex chain lifting 3 pounds of mini tetras on a two stage elevator that weighed another 3+ pounds. The vex chain is plenty strong. Most of the time when the chain parts or occasionally breaks it's due to shock loads or bad alignment of the sprockets causing uneven stress on one side of the chain. Shock loads like sudden starts or stops caused by sticky mechanisms or hitting a wall or robot, etc.
To test the chain strength fix one end of a length of vex chain to something solid connect the other end to a hanging fish scale and slowly pull on the fish scale until the chain parts. Repeat a few times and you'll have a good idea of how strong the vex chain is.
2009 CT Regional Motorola Quality Award
2010 VRC Connecticut Championship Winners & Amaze Award
2010 VRC Championship Divisional Energy Award
2010 WPI Regional Winner
2010 WPI Regional Engineering Inspiration Award
2011 WPI Regional Chairman's Award
2012 WPI Regional Finalists
Unread 15-11-2006, 18:31
DonRotolo's Avatar
Back to humble
FRC #0832
Re: VEX Chains
...and please be sure to share your findings with the rest of us!
Don
Unread 20-11-2006, 11:48
fredliu168's Avatar
fredliu168 fredliu168 is offline
FTC #0478 (Mustang Robotics 478)
fredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud offredliu168 has much to be proud of
Send a message via MSN to fredliu168
Re: VEX Chains
My chain keeps breaking. We use it to lift our conveyer pickup, but I don't think it can handle it...
In 2006
Team Name: 3652 FLAME
Michigan VEX Competition WINNERS
Pennsylvania VEX Competition WINNERS
Atlanta World Championships Runner-up alliance
Only team to win two regionals in 2006
In 2007
Team Name: 478 Mustang Robotics and 163 UHS Robotics
Events:
Toronto FTC Competition - Finalists (478, 163, 298)
MA FTC Competition - Winners! (738, 478, 427)
Unread 20-11-2006, 12:25
chewy's Avatar
AKA: Hayon
Re: VEX Chains
What about doubling or trippleing the chain?
Unread 20-11-2006, 12:35
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
Re: VEX Chains
That's similar to what we tried to do with ours. We had an elevator-type lift to pull us up onto the bar. It worked a few times (at Ramp Riot), but then it broke and then didn't work again. After trying to fix it multiple times (none worked), we tried using string (didn't work) and then just gave up. We decided we would use tank tread instead (way sturdier), and left it at that. After VEX was over, we were sitting in the stands watching the FRC competiton, when a VEX team member realized the clutch (I think that's what he said it was- the green thing on the end of the motor) was stripped.
To wrap up this jumbled post, if you're using the chain to lift your robot, and it's not working, try using the tank tread instead, and check your motor clutch.
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
Unread 20-11-2006, 12:52
chewy's Avatar
AKA: Hayon
Re: VEX Chains
There is one main problem with the treads. The chains held tension even after the power is cut off to the motor. With the tank treads, they will slide down very easily. Thats why i personally think that by putting two or three rows of chains, that will hopefully solve our problems, but we will find out soon....
Unread 20-11-2006, 13:35
chewy's Avatar
AKA: Hayon
Re: VEX Chains
And yes, it was the clutch, so we dont know if the string doesnt work for sure. But i guess that we will test that too.
Unread 20-11-2006, 13:49
Re: VEX Chains
That we will. To quote National Treasure (we watched it in History today) and Nicolas Cage, who quotes Thomas Edison in the movie: "I did not fail 2,000 times at making a lightbulb. I just found 2,000 ways how not to make a lightbulb." (or something like that).
My food for thought for the day.
Unread 20-11-2006, 15:18
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: VEX Chains
I kept breaking chain when I tried to go too far and my lift stopped but I didn't. We put in a limit switch which stopped that issue but still broke some chain. I doubled up the chain and had no more problems.
Another tip. After pulling chain apart remove the stretched link and replace with new. Once weaken they never work the same.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 20-11-2006, 17:01
chewy's Avatar
AKA: Hayon
Re: VEX Chains
Yeah, that is the exact same problem that we were having, when the operator of the chain lift went too far either up or down, it would break. That problem however could easily be solved by adding a limit switch, but we still have chain breaking problems. Thats good to hear that 2 chains work fine. Maybe we will even go up to 3 chains as backups in case the others break...
Unread 20-11-2006, 17:45
Re: VEX Chains
I think the reason ours kept breaking with the stripped clutch may have been because it caused the sliding part to come thudding back down and put the stress under awkward, undesigned force and therefore breaking it. I think a good thing to remember with this when you're frustrated is that the chain's meant to be more of a drive train/power transfer device, rather than part of a robot-lifting device...then again, neither is tank tread, but c'mon- it's tank tread, it's sturdier!!!!
Unread 21-11-2006, 14:14
chewy's Avatar
AKA: Hayon
Re: VEX Chains
The other main advantage to using the treads is that if you go too far or too short, it will not break, you will probably just strip a clutch. always use a clutch so the motor doesnt get damaged.
Vex Announcement: FIRST Vex Challenge Extended for 2006-2007 KathieK FIRST Tech Challenge 14 30-07-2006 23:42
chains sburro Technical Discussion 13 07-10-2004 11:37
power transmission NOT using gears/chains? Frank(Aflak) Technical Discussion 37 21-05-2003 12:50
chains in 3ds tinsLee123 3D Animation and Competition 4 17-02-2003 00:14
chains enjoiwheels Inventor 0 08-02-2003 19:33
