#14
Re: VEX Chains
The other main advantage to using the treads is that if you go too far or too short, it will not break, you will probably just strip a clutch. always use a clutch so the motor doesnt get damaged.
| Vex Announcement: FIRST Vex Challenge Extended for 2006-2007 | KathieK | FIRST Tech Challenge | 14 | 30-07-2006 23:42 |
| chains | sburro | Technical Discussion | 13 | 07-10-2004 11:37 |
| power transmission NOT using gears/chains? | Frank(Aflak) | Technical Discussion | 37 | 21-05-2003 12:50 |
| chains in 3ds | tinsLee123 | 3D Animation and Competition | 4 | 17-02-2003 00:14 |
| chains | enjoiwheels | Inventor | 0 | 08-02-2003 19:33 |
