Go to Post It's all about bragging rights, awards, and pushing the envelope, not necessarily winning or practicality. - ahecht [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 22-11-2006, 15:27
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Dimensions of robot box
Originally Posted by dhitchco
What year did FedEx change the maximum dimensions of the robot shipping box?
It was changed for the 2002 season, I believe. It got smaller by like 4" or something.
2001-2004: Team 100
2006-Present: Team 254
Unread 16-12-2006, 19:29
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Okay, if one where to have rebuilt their crate of many years because something crushed it in transit and destroyed half of your robot on it's way to Atlanta and didn't tell you and you already built a new one that splits down the middle so that you can use it to organize your pit area with shelving, how to you tie down the robot while the crate is in two pieces???
http://www.chiefdelphi.com/media/photos/24789
Do you only tie down on one side
Or do you have a panel that comes off such that you can put the robot in and close the clamb shell design, tie down the robot on both sides and then screw on the panel...
please excuse the run-on sentences
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 16-12-2006, 22:53
DonRotolo's Avatar
Back to humble
FRC #0832
There are many ways: One side only, make a full width 'second' floor to tie it down, use compressible materials to hold it steady, build in arms that hold it when the clamshell is closed... My best advice is to find a commercial package that works that way and see how they did it.
Or my favorite: Tie it down after it's closed. The freshman inside goes for the ride...
Don
Unread 17-12-2006, 12:35
Thumbs up Re: Dimensions of robot box
Don
Some good advice yet it begs the next question, How much Food and Water does one pack in the crate per week until the first regional event This would certianly make the case for attending one of the early regionals
On the serious side, I had not thought of adding in a second floor which is the full 4 x 4 size to tie down to and will likely go with that idea. I always had fun working within the tight confines of the crate already getting tie down straps tight. This way the whole thing can be locked tight outside of the crate and then placed in the crate half, secured and then the clambshell closed.
APS
Founder FRC 499
Dimensions Stormhammer Rules/Strategy 3 10-01-2005 02:40
Robot Simulator Box K0r34nB0y Electrical 4 19-04-2004 20:16
Can LEXAN exceed robot dimensions? RAWdealer59 Rules/Strategy 13 05-03-2003 22:05
Weird Moving-Box (or any Big Box) uses Kristina Chit-Chat 5 25-06-2002 17:19
Robot dimensions & weight restrictions revealed? Mike Soukup Rules/Strategy 4 24-10-2001 20:51
