Go to Post Note to self for next year, apply physics rather than "well, this SEEMS like it would work." - Karibou [more]
Go Back   Chief Delphi > Competition > OCCRA > OCCRA Q&A
Unread 23-11-2006, 09:14
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
[OCCRA]: Championship bracket
Hey,
I thought I was doing pretty well, understanding everything that was going on, until we came to the championship. I don't understand how you determine who goes when. I understand this much:
Each team's top 12 seeding matches alliance totals are added together, then the teams are ranked by this total. Starting from the highest ranking, each team gets to choose another team to become their alliance. Beyond this, I'm lost--can #1 select #2? Does that mean the 13th ranked team slides up and gets to select a team for their alliance? Also, how does anyone determine which alliance plays when? Could you possibly post the bracket you used, and give an explanation to a newbie?
Thanks so much...for putting up with me!
JBot
Aren't signatures a bit outdated?
Unread 23-11-2006, 14:40
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Re: [OCCRA]: Championship bracket
Question:
Originally Posted by JBotAlan
Hey,
JBot
Answer:
We use the tournament trees at this link: http://calontir.sca.org/marshal/tournament-trees-de.pdf
There are others but in the past few years w have used the trees from this site. We use the 16 team, double elimination.
We use the 16 team because in OCCRA there was 24 to 27 teams if all played. This is actually 12 to 14 alliances as each alliance is made up of two teams. Tournament trees that are double elimination are based upon brackets of 8. The brackets are called NCAA style as the top teams play the bottom teams, a common format that rewards the top teams and keeps the top teams from eliminating each other early.
As in past years teams are ranked based upon their 12 best matches. Some teams may play as many as 18 matches. This is because a few teams did not participate in the womens tournament. There were 2 seeding matches played at the Championship.
The teams were ranked and brought out on the field and put in order 1 to 24 as there were 24 teams.
The top 6 ranked teams cannot select each other (this is clearly stated in the OCCRA team rules). Starting with the top seed each selects a alliance until all teams are selected. This process besides written out was reviewed at several tournaments and drivers meetings.
The teams are then placed in the tree with the appropriate byes. The tree we selected uses the NCAA format which plays the top teams against the bottom teams. This ensures that the top teams cannot eliminate each other until the quarter finals.
All matches were single matches until we reached the final four teams then it became best 2 out of 3. A losing team goes to the losers bracket. A team is not eliminated from the tournament unless they lose two matches. Once the top 4 teams are set a team still has to lose 2 matches, therefore it is possible that a team coming from the losers side may actually lose 3 games or more and end up a winner. This all depends on the situation and order of match play.
Bottom line is ...... the brackets are NOT made by us and team rankings determine who goes where at what time.
If you or your team leader has other suggestions please have them presented at the end of season meeting for consideration. This meeting determines what the competition will look like for the next season.
Mike Martus
[OCCRA]: County Championship Question surferacf OCCRA Q&A 1 14-11-2006 06:44
[OCCRA]: VEX at championship Chief Samwize OCCRA Q&A 1 12-11-2006 07:55
pic: 2005 Championship Bracket Goobergunch Extra Discussion 5 24-04-2005 12:16
[OCCRA]: Final Pre-Championship Standings Nate Smith OCCRA 4 16-11-2004 09:34
Is an angle bracket allowed? archiver 2001 0 24-06-2002 00:58
