Go to Post “Nothing defines humans better than their willingness to do irrational things in the pursuit of phenomenally unlikely payoffs” - Scott Adams - 114Klaatu0x72 [more]
Unread 25-11-2006, 15:02
miketwalker miketwalker is offline
Robot Lifeguard
FRC #1902 (Exploding Bacon)
miketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond reputemiketwalker has a reputation beyond repute
Send a message via AIM to miketwalker
Trig. Functions in EasyC
I haven't been able to find an answer to this on any of the Vex forums so I figured I'd throw it here. The students on our Vex team are working on a concept with their autonomous and need to be able to use trig functions (primarily tangent) but they can do everything else they are working with in EasyC if they can get the value of a calculation using these trig. functions. Unlike MPLAB it seems that you can't just plug in a math header file and use it like in FRC, but perhaps I am wrong. Has anyone does this and/or any suggestions on how to go about doing it? Thanks!
Chopsaw? Chopsaw.
Unread 25-11-2006, 16:35
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Re: Trig. Functions in EasyC
You can approximate sin very well between -PI/2 and PI/2 with the function f(theta) = theta - theta3/6 + theta5/120.
Once you've got that approximation, you can basically compute any sin value by using the periodic properties of sin.
sin(x) = sin(PI - x) between PI/2 and 3PI/2 (this recursively uses the bit we can accurately approximate)
sin(x) = sin(x - 2PI) between 3PI/2 and 2PI.
Here's the code for sin:
#define PI 3.14159
float ApproxSin(float theta)
    while(theta > (3*PI)/2)
        theta -= 2*PI;
    while(theta < -PI/2)
        theta += 2*PI;
    // theta is now between -PI/2 and 3*PI/2
    if(theta > -PI/2 && theta <= PI/2) // basic approximation
        return theta - theta*theta*theta/6 + theta*theta*theta*theta*theta/120;
    else if(theta > PI/2 && theta < 3*PI/2)
        return ApproxSin(PI - theta);
An approximation for cos is f(x) = 1 - x2/2 + x4/24, you can do the same thing with it, more or less.
Unread 27-11-2006, 13:42
AKA: Brad
#0190 ( Gompei and the Herd)
The Microchip libaries include math functions. Be sure to add an include for math.h so that the correct types are passed to the functions.
Brad
Brad Miller
Robotics Resource Center
Unread 27-11-2006, 21:46
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
I would like to suggest, without actually knowing your specific application, that you might want to utilize a lookup table. If it is a situation where you need to do the calculations many, many times, then a lookup table will save you computation time as trig functions do have some overhead. Precalculate your trig function for, say, 0-359 degrees and plug the values into an array (indexed 0-359 of course!). Then when needed you just index the array for the answer. If this is a navigation application 0-359 degrees should really be enough resolution, given the error inherent in the sensors. The only drawback is, of course, you have to use up memory to store the array of floats.
Unread 04-12-2006, 08:16
Bongle's Avatar
I always forget about lookup tables
I'm not sure how much code space the VEX controller has, but 360 floats in a table is 1440 bytes, which is quite a bit. Another idea in that vein would be to have a smaller table (45 entries) and just interpolate between them.
float GetSin(int degrees)
  int subDegrees = degrees & 7; // gets the last 3 bits
  int tableIndex = degrees / 8; // finds out the table entry we want
  return ((8-subDegrees)*table[tableIndex] + subDegrees*table[tableIndex+1])/8;
This function is a very simple linear interpolation. But it would allow you to have a much smaller table taking up much less memory. Another improvement would be to only have a table for between -PI/2 and PI/2, then using the same techniques I posted in my first post to get answers for PI/2 and beyond. This would again cut table size in half.
Unread 07-12-2006, 23:27
AKA: Dan
This is good stuff! Excellent suggestions!
Organize EasyC functions in a fashion we like? Chris_Elston Programming 3 20-02-2006 18:53
speed of math.h trig functions? Jared Russell Programming 4 07-02-2006 07:13
Calling C functions from EasyC koenig3456 Programming 4 27-01-2006 16:03
Trig functions and type conversion kaszeta Programming 6 14-01-2006 23:34
Return of the Inverse Trig Functions Leo M Programming 3 24-01-2002 08:12
