Go to Post Wow, possibly a HPJIE*? How cool would that be? *High Paying Job In Electronics. - DonRotolo [more]
Go Back   Chief Delphi > Other > Math and Science
Unread 25-11-2006, 23:52
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Lagrange Multipliers
Ok, I'm having a problem understanding a question about Lagrange Multipliers.
Given the function f(x, y) = 16 − x2y2 and the constraint (x − 1)2 + (y − 1)2 = 4, find the maximum and minimum.
I've reduced it to the system:
  1. -2x = λ∙2x
  2. -2y = λ∙2y
  3. (x − 1)2 + (y − 1)2 = 4
There are a few ways to solve this:
  • Assume λ = -1, which gets you nowhere
  • Assume x = 0, for which y = 1 ± √3
  • Assume y = 0, for which x = 1 ± √3
I know that the real answer is when x = y, but I can't get that going forwards.
Anyone have suggestions as to how to approach it?
Unread 26-11-2006, 00:50
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Lagrange Multipliers
1. and 2. of your system are incorrect. The left hand side is correct, but the right hand side is wrong. What is the derivative of (x-1)^2 with respect to x? Ditto (y-1)^2 w.r.t. y. You might try fully expanding the expression and then deriving it if you're still getting 2x and 2y.
Hint: The chain rule always applies in derivatives, everywhere, all the time.
Unread 26-11-2006, 01:12
AKA: Jamie Bliss
Darned me and those shortcuts. I didn't think the constant offset would change it much.
Ok, it doesn't. Just 2(x - 1) instead. It's always the little things.
All these time multipliers.... archiver 2001 0 24-06-2002 02:53
Multipliers (SC6 and SC7) archiver 2001 2 23-06-2002 22:43
How do multipliers combine??? archiver 2001 2 23-06-2002 22:40
