SF and RM
Hi everybody.
I bought CMUCam2 and I want to ask you two questions. Firtst, when I am sending the 'SF' command, is there a way to see the form of F-packets and make the non-visible ASCII characters visible? Second, what means raw bytes packets? I can't understand the meaning from the manual. Can you give me an example of raw modes? I would appreciate any help. Thank you in advance.. NM |
Re: SF and RM
if you want to look at some good code for the camera look at kevin's code (www.kevin.org/frc). His code is great, even if you don't use it.
Re: SF and RM
Kevin Watson also has the PDF datasheets that have alot of info. Ill pull out my CMUCam and see if i can answer your question.
Re: SF and RM
Take a look at this thread for more about the format of SF packets.
http://www.chiefdelphi.com/forums/sh...ad.php?t=48821 |
Re: SF and RM
A theoretical ASCII packet would look like this:
X 54 42 35\r Code:
X\x36\x2A\x23\r |
| Bill of Materials, do it and do it well, and bring it to your event | sanddrag | Rules/Strategy | 3 | 24-03-2006 21:09 |
| Thank you 1359 and 1569 and Congrats 492, 1595, 604 | SilverStar | Thanks and/or Congrats | 0 | 13-03-2005 23:21 |
| pic: Stars and Stripes over Einstein and Galileo | CD47-Bot | Extra Discussion | 6 | 01-05-2004 00:54 |
