Go to Post There's blood in the water and the Piranhas are biting. It's CD. This thread is gonna have legs all the way til January 9th. - Koko Ed [more]
Unread 27-11-2006, 09:09
nmihailidis nmihailidis is offline
nmihailidis is an unknown quantity at this point
SF and RM
Hi everybody.
I bought CMUCam2 and I want to ask you two questions.
Firtst, when I am sending the 'SF' command, is there a way to see the form of F-packets and make the non-visible ASCII characters visible?
Second, what means raw bytes packets? I can't understand the meaning from the manual. Can you give me an example of raw modes?
I would appreciate any help.
Thank you in advance..
NM
Unread 27-11-2006, 10:21
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: SF and RM
if you want to look at some good code for the camera look at kevin's code (www.kevin.org/frc). His code is great, even if you don't use it.
Eric Haskins KC9JVH
Unread 27-11-2006, 12:04
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: SF and RM
Kevin Watson also has the PDF datasheets that have alot of info. Ill pull out my CMUCam and see if i can answer your question.
Unread 27-11-2006, 18:52
divergentdave divergentdave is offline
FRC #1816 (Green Machine)
divergentdave is a jewel in the roughdivergentdave is a jewel in the roughdivergentdave is a jewel in the rough
Send a message via AIM to divergentdave
Re: SF and RM
Take a look at this thread for more about the format of SF packets.
http://www.chiefdelphi.com/forums/sh...ad.php?t=48821
Team 1816 - The Green Machine
Unread 27-11-2006, 23:19
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: SF and RM
A theoretical ASCII packet would look like this:
X 54 42 35\r
While the equivalent Raw mode packet would be:
X\x36\x2A\x23\r
It allows you to write simplier serial drivers because each byte is the value, not some character that represents a part of the value.
Bill of Materials, do it and do it well, and bring it to your event sanddrag Rules/Strategy 3 24-03-2006 21:09
Thank you 1359 and 1569 and Congrats 492, 1595, 604 SilverStar Thanks and/or Congrats 0 13-03-2005 23:21
pic: Stars and Stripes over Einstein and Galileo CD47-Bot Extra Discussion 6 01-05-2004 00:54
