Re: Mecanum Suspensions
Team 357 Royal Assualt used a suspension on the back wheels of our jester drive
It helps alot. In order for this drive train to be able perform well all 4 wheels need to be in contact with the floor. we have used this drian train for 2 years now. we used it in 2005, we did not use a suspension and in some cases it did not perform how we wanted it to. In the 2006 game we put in a suspension and we saw a better result. As a driver, i drove both robots in competition and it is much more controllable and more reliable with a suspension. Last edited by JESTER357 : 28-11-2006 at 22:18. |
The kitbot frame is so flexy you might call it a suspension all of its own. I haven't really decided if it is better to have a super rigid frame or not. For mecanum or omni, some sort of rubber pad may suffice. For any past game, most any real suspension would be too heavy for any benefit if you ask me. I wouldn't mind seeing a game that really required some sort of suspension, although it will probably never happen.
Thanks for the responses!
How did you use suspension on only 2 wheels on Jester Drive? Why not 4? Also do you have any pictures? Thanks a lot!! |
If you put it on all four, it works, but then the body of the robot becomes (potentially) unstable, because it's now supported on four moving pivots. It's like body roll in a car, only probably quite a bit more pronounced. |
as soon as i get a picture i will give post it .... but a team that i am pretty sure used independant suspension for each wheel is trinity team 40. if u want video on how it did .. you might not be able to tell the difference but we went to the florida regional, drexel and champ. which are both supported by soap. i will get pictures of our frame asap
http://www.soap.circuitrunners.com/2006/movies/florida/ florida http://www.soap.circuitrunners.com/2006/movies/philly/ drexel http://www.soap.circuitrunners.com/2...es/archimedes/ champs |
Personally i think, that if your are going for a high maneuverable drive system that does not really have that much grip to it, it would help to have an adjustable suspension because then you can shift the center of gravity and put more weight on a wheel or a set of wheel, which would increase traction. However if the weight of the suspension takes away from you a key scoring ability then it is not worth the time, effort, or weight
#7
remember when you weld a frame, it warps because of thermal expansion. In 2005 my team had a frame with a lot of welds. Did one side first, flipped over and did the other side. When it cooled down, it was slightly cuved upward. Didn't matter much, but imagine if it curved the corners up? A mecanum bot with a frame like that would not drive very straight.
#8
I believe that a mecanum system actually needs every wheel on the ground because the direction is controlled by a different vector from each wheel. If a wheel isn't touching the ground, the robot would drive at the wrong angle because force in one direction is missing, while the bot is programmed to use all four vectors. (Unless the robot was programmed to change its math based on which wheels are touching the ground...) |
#9
While I don't have experience with the Mecanum drive, our team has done a harmonic drive for a couple of years which is pretty much the same thing. When we first put together our drive the chassis would steer off in random directions because the floor (and no floor will be ,ever) wasn't perfectly flat (we had shimmed the wheels to be flat). This is why you use a suspension so that all wheel can stay in contact with the floor and cause good control of the vectors. Our first suspension was with each wheel mounted on a hinge and a spring, this would tilt whenever the robot would accelerate in any direction. So this year we used a "tractor" type of suspension. This didn't add any weight really but kept all wheels in contact always.
http://www.chiefdelphi.com/media/photos/22700 We also added a rotational accelerometer to keep track of any variation in the bots direction of travel and last year when I broke out our original chassis for the first time in months so the programmers could work with it one of the motors wasn't plugged and we didn't notice. Despite the lack of an entire vector the accelerometer allowed the robot to drive straight (if a little drunkenly). Hope this helps Alex |
#10
| Mecanum | Rob2713g | Technical Discussion | 13 | 03-11-2006 14:16 |
| Mecanum Wheels | chaolin2007 | Control System | 1 | 25-02-2006 19:16 |
| Mecanum Wheels | TheFerret | Technical Discussion | 8 | 16-01-2006 09:23 |
| mecanum patents | piotr_boch | Technical Discussion | 6 | 25-11-2005 20:03 |
