Go to Post People will only work toward common goals when they are part of the goal-setting process. - GaryVoshol [more]
Unread 29-11-2006, 14:03
Guy_E Guy_E is offline
FRC #1574 (MisCar)
Guy_E has a spectacular aura aboutGuy_E has a spectacular aura about
Send a message via MSN to Guy_E
Problems with the Gyro
Hi,
I started to learn how to use the gyro. I downloaded Kevin's code from the internet and tried to use it. There are some things which I haven't understood completely.
I tried to print the variable "gyro_rate", but its values were between 1800-2200.
Shouldn't it be much lower? Shouldn't this variable be measuring the angular velocity in (radians/seconds)? I don't know if there is something wrong with the code, or something wrong with my understanding. I then tried to print the value from the function Get_Gyro_Angle(), but again, the printed values were unreasonable. The value jumped from positive to negative numbers without any logical order.
I would be very glad if someone could guide me through it.
Thanks,
Guy
Team #1574 Misgav High School - Israel
Winner of the 2007 Israeli Regional
Winner of the 2007 Motorola Quality in Design Award
Visit our website:
www.miscar1574.com
Unread 29-11-2006, 14:13
neilsonster's Avatar
neilsonster neilsonster is offline
AKA: Andrew Neilson
FRC #0772 (Sabre Bytes)
neilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to allneilsonster is a name known to all
Send a message via MSN to neilsonster
Re: Problems with the Gyro
Originally Posted by Guy_E
Hi,
Thanks,
Guy
I haven't used the gyro code in a little over a year, but if I remember right the angular unit used in Kevin Watson's gyro code is milliradians, not radians. You should also be able to change it to tenths of a degree in the gyro.h file. That would at least explain the large numbers you were getting.
Sorry I don't know the complete answer to your question, but it's a start.
Andrew Neilson - Team 772 Alumnus
University of Waterloo Computer Science, Class of 2010
Unread 29-11-2006, 14:33
Back after 4 years off
FRC #5279
Hey, I don't have the code in front of me but I can look at it when I get back to my dorm.
For your First question neilsonster is right about the units. That would explain the large numbers 1.8 radians per second is alot easier to explain than 1800. I am assuming that the values you are giving us are when the robot is at rest if this is not the case then please specify what you are doing to the robot while it is printing out the data. If the robot is just sitting there than your problem is probably in the initialization of the gyro. When you enable the robot let it sit for a second or two, also make sure the gyro isn't too close to the compressor or anything else that may cause it to vibrate. If this doesn't help then give us any more information that you can and I'll try again.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 29-11-2006, 14:47
FRC #1574 (MisCar)
The value of "gyro_rate" is about 2030 while not moving. When I do rotate the gyro the value decreases or increases depending on the direction. My guess is that the gyro is somehow not calibrated or initialized well, but I don't know how to make it correct....
Visit our website:
www.miscar1574.com
Unread 29-11-2006, 18:08
Noah Kleinberg Noah Kleinberg is offline
FRC #0395 (2TrainRobotics)
Team Role: Driver
Noah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to beholdNoah Kleinberg is a splendid one to behold
Send a message via AIM to Noah Kleinberg
That sounds like a problem with the bias. You should try calling Get_Gyro_Bias() and printing the return value, which I think should be something relatively close to 512 if I remember correctly, also make sure that you called Initialize_Gyro() at some point in the code, otherwise it might be the case that the variable holding the bias was never initialized, and contains a random number, offsetting all of your data by that number.
Unread 29-11-2006, 21:51
eshteyn's Avatar
eshteyn eshteyn is offline
WOOPS! shorted the deep cycle batt.
AKA: the supply seargent, Eugene
FRC #0375 (the robotic plague)
eshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really niceeshteyn is just really nice
Send a message via AIM to eshteyn Send a message via Yahoo to eshteyn
hey , whats up, ask our programmer Dan about the gyro, we put one in Rambo last year and Dan has some great experience with it, good luck.
Championship - Delphi "Driving Tomorrows Technology"
Unread 30-11-2006, 06:12
FRC #1574 (MisCar)
I printed Get_Gyro_Bias ans the outcome was 0. What does this value represent? I call Initialize_Gyro in User_Initialization, where Kevin located it.
Visit our website:
www.miscar1574.com
Unread 30-11-2006, 07:04
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
I havent used to gyro but if i recall it is supposed to be 512 for the x and 512 for the y when they gyro isnt moving. Then then you start moving it values will vary from 0 to 1023.
Unread 30-11-2006, 07:05
FRC #1574 (MisCar)
Any idea what the problem could be?
Visit our website:
www.miscar1574.com
Unread 30-11-2006, 11:54
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Do you have your code calling the StartGyroCalibration() and StopGyroCalibration()?
If you tried to integrate Kevin's code into your own code you might not be initializing the gyro correctly. Look at the ProcessDataFromMasteruP() in Kevin's code.
Eric Haskins KC9JVH
Unread 30-11-2006, 13:57
aviv aviv is offline
FRC #1657
aviv will become famous soon enough
You need to set the gyro's bias.. You do this by using the Start_Gyro_Bias_Calc() and
Stop_Gyro_Bias_Calc(). Let The start_bias_calc() run for a few secs while the robot isn't moving.
If you need anymore help u can email me at avivgalon@gmail.com
I haven't seen you for a while... (Samur)
Winner of 2006 GM/Technion Israel Regional
Chairman's Award 2006 GM/Technion Israel Regional
Best Website 2006 GM/Technion Israel Regional
HaMosad Robotics #1657
Unread 30-11-2006, 16:32
6600gt's Avatar
6600gt 6600gt is offline
AKA: Lohit
FRC #0226 (Hammerhead)
6600gt is a jewel in the rough6600gt is a jewel in the rough6600gt is a jewel in the rough
If you are using Kevin Watson's code, Get_Gyro_Angle is giving you the actual calculated angle 1800 is 180.0 degrees. He removed the decimal to help the pic process faster(it sucks at floating point stuff).
The actual gyro only outputs the angular rate but his code integrates to give you the actual angle at that point in time.
Read the "Readme" file that came with the gyro code. It should help you setup and calibrate the whole gyro.
Unread 01-12-2006, 07:35
FRC #1574 (MisCar)
I'm such a fool. I forgot that there was code executed in the Process_Data_From_Master_uP function, and I worked with the gyro with the RC turned off...
When I did work with the RC switched on, the gyro's bias was indeed calculated, but its value was 2040.... As a consequence, I believe, the angle and the angular rate were not calculated correctly.
Any idea how can I correct it?
Visit our website:
www.miscar1574.com
Unread 02-12-2006, 09:52
FRC #1574 (MisCar)
Please, someone?
Visit our website:
www.miscar1574.com
Unread 02-12-2006, 10:19
AKA: Eric Haskins
Try running a "clean" copy of kevin's code . Then if the gyro acts correctly you'll know its your code. If it still has problems it could be a hardware issue.
Eric Haskins KC9JVH
Problems with the gyro Conan Programming 7 06-02-2006 01:45
Gyro Code Problems railerobotics Programming 8 27-01-2006 10:45
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
Help with the gyro chip Team852 Electrical 1 10-01-2003 22:31
