Go to Post Here, and in general, avoid jumping to conclusions without research. This will serve you well in life. - DonRotolo [more]
Unread 10-07-2006, 11:05
Romeo1351's Avatar
Romeo1351 Romeo1351 is offline
Your Friendly Neighborhood Geek
AKA: Nicholas Corgan
FRC #1351 (Mitty Robotics)
Team Role: Webmaster
Romeo1351 is an unknown quantity at this point
Send a message via AIM to Romeo1351 Send a message via Yahoo to Romeo1351
Unhappy Problem downloading code
Hi, I'm new to VEX, and I'm having problems downloading code to the controller. When I turn the controller on, it has a blinking or solid green light. I click Download on IFI Loader, and it says to hold down the PROG Button until the light becomes solid orange. I've been doing that, and nothing has been happening. Has this happened to anyone? Do you know the solution?
"We're nonessential engineers! If this were Star Trek, we'd be dead!"
---1351's Katie, SVR '06
Currently: Website Head, Programmer
Unread 10-07-2006, 11:20
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: Problem downloading code
Are you pressing the program button BEFORE you hit download? Also, make sure that you have securely attached the cable into both the computer and the controller. In addition to that, make sure that the proper port is set in IFI Loader. I've made that mistake far too many times.
I hope that helps. Sometimes it's the silliest mistake that is causing the problem.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 10-07-2006, 11:24
Romeo1351's Avatar
Smile Re: Problem downloading code
You're right. It is the silliest problem. I think I'm pressing the PROG button after I press Download. Thanks, I'll pressing it before, and I'll come back with results.
Unread 10-07-2006, 11:49
Romeo1351's Avatar
Thanks. The code downloaded. Everything's working.
Last edited by Romeo1351 : 10-07-2006 at 11:53. Reason: It's good to have communication from the transmitter to the receiver before saying it's not working...
Unread 30-11-2006, 14:13
dmellich dmellich is offline
AKA: Mr. E
FRC #1251 (TechTiger Robotics)
dmellich has a spectacular aura aboutdmellich has a spectacular aura aboutdmellich has a spectacular aura about
I have a download problem but different type. When I turn on the controller, the PGRM Status light is solid green. I noticed that when power is applied to my other unit the PGRM Status light does not come on. I am able to download to this second controller using the same computer and settings. Any thoughts? Thanks.
David M. Ellich
Team 1251, TechTiger Robotics
South Florida Regional Planning Committee
"It's Cool to be Smart"
Unread 30-11-2006, 15:51
Graham Donaldson's Avatar
Graham Donaldson Graham Donaldson is offline
AKA: Graham Donaldson
FRC #1676 (The Pascack Pi-oneers)
Graham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant futureGraham Donaldson has a brilliant future
How old is the second unit? Stupid answer, but maybe the light's burnt out. I can't think of any reason to worry about it if it downloads and runs properly.
If it's not that, I'm not sure.
2008 NJ Regional, 2009 Palmetto Regional: Chairman's Award Winners
2010 NJ Regional Champions (w/ 25 and 3059), 2010 VA Regional Champions (w/ 1086 & 1418)
"Hard work spotlights the character of people: some turn up their sleeves, some turn up their noses, and some don't turn up at all."- Sam Ewing
"Opportunity is missed by most people because it is dressed in overalls and looks like work."- Thomas Edison
Unread 01-12-2006, 06:33
AKA: Mr. E
I don't think the issue is with the PGRM Status light - the light is off on all other controllers that I've seen download OK. It appears the by the light being on, it is indicating some type of error.
David M. Ellich
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
Problem Downloading from Streamline petek Inventor 2 10-03-2005 21:07
Problem downloading any Camera code zuckie13 Programming 4 07-02-2005 20:32
Beginner problem with downloading pagemauck Programming 2 17-01-2004 13:24
Downloading Problem to EDU Motherboard Jankenpoe Programming 0 16-02-2003 14:29
