Go to Post "We put the eek in Geek" - Wayne Doenges [more]
Unread 27-11-2006, 20:21
JWSnedden's Avatar
JWSnedden JWSnedden is offline
Profundity Escapes Me...
AKA: Le Comte de Rien
FRC #1646 (Precision Guessworks)
Team Role: Webmaster
JWSnedden is an unknown quantity at this point
Limit Switch Basics
How do you program limit switches?
Behold the Awesome Power of my 16M Jump Drive!!!!!
Unread 27-11-2006, 20:36
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: Limit Switch Basics
I am not the programmmer, but I am the electrician on our team. A limit switch plugs into a digital I/O port on the controller. The switch is closed when the negative is applied (or so I believe and please correct me if I'm wrong). As far as the programming, I have no idea. So it uses the black and white wires of a PWM cable. When the switch is closed, the program is supposed to respond.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 27-11-2006, 20:40
JWSnedden's Avatar
yes, we knew that. We need to program it. Thank you, though.
Unread 27-11-2006, 20:49
Electrical Engineer
Rookie Year: 1995
JWS,
When the switch is closed, you will read a 0 and then the switch is open, you will read a 1...
if (rc_dig_in15 == 0)
   // This will execute when the signal on input 15 is grounded.
  else
   // This will execute otherwise (when the switch is open).
Does this make sense?
Mike
Mike Betts
As easy as 355/113...
Unread 27-11-2006, 21:34
JWSnedden's Avatar
Yes Thanks very much!
Unread 30-11-2006, 18:58
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
#define leftLS rc_dig_in15
#define rightLS rc_dig_in14
if(leftLS == 0)
//the left limit switch is on
//dont turn left any more
if(rightLS == 0)
//the right limit switch is on
// dont turn right any more
//this post made more since before the nevermind
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 30-11-2006, 19:48
JWSnedden's Avatar
Thanks anyway!
Limit switch in easy c? chadbarbe Programming 6 02-02-2006 09:51
How do you wire a limit switch? JMH Electrical 1 16-02-2005 17:44
gyro/accelecometer/limit switch help needed Anton Programming 4 04-02-2005 16:39
sample limit switch code??? tml240 Programming 5 17-02-2004 17:13
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
