Go to Post The fact that although many of us disagree on specifics of how FIRST should conduct events, design a game, and facilitate as much fairness between teams as possible, in the end we still greatly enjoy each other's passion for FIRST and provide genuine respect for each other - Andy Baker [more]
Unread 30-11-2006, 22:11
Josh Siegel's Avatar
Josh Siegel Josh Siegel is offline
lurker
#0448 (Crandroids)
Josh Siegel will become famous soon enough
Send a message via AIM to Josh Siegel Send a message via MSN to Josh Siegel
2004 Edubot Serial String Help (TTL in)
Hi everyone,
I've been fooling around with this code for awhile and I'm at a total loss as to what I can try next. Here's what I aim to do:
-I have an RS232 GPS device that is tested and known good.
-I have a TTL to RS232/RS232 to TTL conversion board that is tested and known good
-I want to read, and ultimately parse, the data string (but don't know about C string parsing). For now, I would be happy with printing it out from the RS232 (feed in TTL and out to PC).
I tried Kevin's serial code, but it never actually seemed to read the data. A few times, I got it to "acknowledge" that it captured something (just a simple print if this portion is reached), but it never printed it properly. It also only did it once per boot of the board. How does the EDU know when a string is coming in? I know I can use interrupts, but that seems like an awful lot of trouble to set up a reader for a GPS device.
Does anyone have experience with this? Sample code, perhaps?
I'd post what I have, but its mostly the default serial code, with the parameters changed to 4800 baud.
Thanks,
Josh
Serial Port Help? StargateFan Programming 12 05-07-2006 14:06
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
TTL Serial Port and PS2 Mouse Interface cbolin Electrical 8 29-12-2004 15:00
EduBot Help, RC Controller Allison K Robotics Education and Curriculum 5 29-03-2004 16:48
USB to 9-pin serial port (HELP!!) n00b Technical Discussion 10 01-02-2004 21:25
