Go to Post I love the dedication of Robotics kids. :) - Danielle H [more]
Unread 01-12-2006, 16:04
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Inventor 10 - Installation Error 1603
For about three days now, I've been trying to find help from both Autodesk and Microsoft, and I've gotten nowhere. The error is a very general error for failed installations, using a Windows Installer, which this does. According to the log file, the error occurs while trying to install Windows WSE 2.0 Runtime, the very first thing the disk tries to install. Has anyone else encountered such an error, or do you have any idea how I might fix it. I'm about the only CADder on my team right now, and there's a lot of stuff that needs to be done.
http://usa.autodesk.com/adsk/servlet...linkID=4183228
I did find this on the Autodesk website, but it doesn't seem to be helping me much.
void function(void)
  function();
Unread 01-12-2006, 16:17
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
Re: Inventor 10 - Installation Error 1603
Have you tried the Autodesk discussion groups? That's often more helpful than the Knowledge Base.
http://discussion.autodesk.com/index...?categoryID=21
Try searching "error 1603" or "1603".
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 01-12-2006, 17:30
void* Jake;
FRC #1178 (DURT)
I have made a post in the groups, but no replies have come yet.
void function(void)
  function();
Unread 01-12-2006, 21:53
void* Jake;
FRC #1178 (DURT)
Problem solved: Having Microsoft.NET Framework 2.0 **BETA** causes an error during installation. You have to remove it and either download 2.0 post-Beta, or let the Inventor disk install 1.1.
void function(void)
  function();
Unread 01-12-2006, 22:00
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Also, what kind of os do you have? I tried installing it on an xp x64, and it said an error, I forget which, and then purchased another hdd for xp pro, and works fine. Also got me a free upgrade to vista.
Unread 02-12-2006, 00:00
void* Jake;
FRC #1178 (DURT)
I have XP Pro, Service Pack 2. Win64 stuff is probably still a bit too new to expect things to always work perfectly, though.
void function(void)
  function();
Unread 02-12-2006, 00:23
Jeff K.'s Avatar
Hmm..now what?
Yeah, but it's getting there. The newest Inventor 11 is x64 and should be Vista compatible...I think.
Edit: somehow I totally overlooked the post that it was because of the Microsoft.NET Framework...what 6 hours of sleep this week makes you do.
Installation Error Heretic121 LabView and Data Acquisition 5 21-01-2006 23:26
MAX 8 installation issue vashthestampede 3D Animation and Competition 18 20-01-2006 09:33
inventor help-installation mess up Simon Strauss Inventor 2 16-01-2006 23:02
Software Development System Installation Mike Betts Programming 26 25-07-2005 10:48
Inventor problem! Dimension Error squeeks548 Inventor 8 11-01-2005 07:32
