Go to Post FIRST kids never cease to amaze me. - Wayne C. [more]
Unread 02-12-2006, 20:16
jfelser jfelser is offline
FRC #0948
jfelser will become famous soon enough
Send a message via AIM to jfelser
pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing
Code Red Robotics Team 639 | www.team639.org
2004 Canadian SUPER Regional Winners with 33 & 1112, GM Industrial Design Award
2005 Finger Lakes Regional Winners with 191 & 494, Canadian Regional GM Industrial Design Award
Newport Robotics Group Team 948 | www.nrg948.org
2006 Portland Regional Motorola Quality Award Winners
2007 Portland Regional Finalists with 1540 & 1778, GM Industrial Design Award
-Jake Felser-
Unread 02-12-2006, 20:33
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
Re: pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing
Nice Inventor work! A+ for the gears and sprocket if you made them yourself?
Looks familar!
I would be interested in the drawings and would check them out for you.
Coming from an experienced Ball Lock transmission team; this type of transmission is a winner! Shift any transmission once your hooked; shift a Ball Lock twice and you will never turn back!
Any idea how your side plates are going to look and what tooth count are your gears?
Now that you have the hard work done, get those machines running!
One thing that could shed some wieght would be to get hubless gears or machine those hubs off.
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 02-12-2006, 21:14
REVving up for a new season
FRC #2848 (All-sparks)
looks great! congrats. I was curious from both you and anyone from 222 that reads this.
1) how do you cut the grooves for the balls? do you just use an end mill or do you get them wire EDMed.
2) What kind of tolerance do you need to hold on the shafts and gear cuts to make the system sloppy (reduced torque transmission)?
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 02-12-2006, 21:19
FRC #0948
The designs for the transmission can be found at http://www.nrg948.org/pr/2 Speed Ball Gearbox_0.2.zip, feel free to download them and look them over. They were made in Inventor 6, but I believe the newer versions shouldn't have too much of a problem opening the files...
Nope - many thanks to FIRST CAD library for their excellent work.
Looks familar!
Hehe, it's funny that you recognize it... I had your white paper on this type of transmission open for reference the entire time I was modeling Obviously your ideas are present all through the design.
I modeled the side plates as well, but took them out in the rendering so that you could see the inner workings of the shifting better. The larger gears are 60T, the smaller ones 35T. The gears on the drive outputs are 14T.
We will definitely be doing this, at least for the keyed gears, in the actual transmission.
-Jake
-Jake Felser-
Unread 02-12-2006, 21:25
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
that looks awesome!
we've been discussing the idea of a ball-lock shifting transmission, and everything is just so great about it.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 02-12-2006, 21:35
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I tend to think the sliding friction and wear of the gears on the shaft isn't.
Unread 02-12-2006, 21:54
AKA: Bradley Rigdon
So your saying dogs don't wear on the gears either?
Milling the four slots into the gears with a mill bit is easy. Slap the bored out gear on the mill vise, dial indicate it on center, move the table to each slot, and your done. (If you have a digital readout lucky you!)
We do not have access to this wire EDM you speak of!
These transmission can be built with a mill and lathe.
The tolerance is usually about 4-5 thousands. In other words, if your shaft was 1.000'' you would bore the gear diameter out to 1.004'' I do believe we have made that gap as much as .01''
Unread 02-12-2006, 23:35
Athleticgirl389's Avatar
Athleticgirl389 Athleticgirl389 is offline
I Am The Robot
AKA: Ashley Marshall Aka Sharpie
FRC #0102 (Gearheads)
Athleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond reputeAthleticgirl389 has a reputation beyond repute
Send a message via AIM to Athleticgirl389 Send a message via MSN to Athleticgirl389 Send a message via Yahoo to Athleticgirl389
I never would have thought of having a 2-speed for shooting. That is very creative!!! Great job on the inventor there! I am new to inventor myself... learning quite quickly... hopefully I can something that kool one day haha. But I am very impressed!!!
2010: New Jersey Regional Quarter Finalist, J&J Gracious Professionalism Award. Connecticut Regional Champions (With 1124 & 383)
2009: New Jersey Regional Quarter Finalist. SBPLI Long Island Semi-Finalist, Motorola Quality Award. Newton Division Semi-Finalist (2970 & 33), BR^2 Champion (With 2793 & 136) & Highest Scoring Match Award
2008: New Jersey Regional Quarter Finalist, Judges Award (Innovative Financial Management). SBPLI Long Island Regional Winner (With 2487 & 2010), Entrepreneurship Award. Fastest Robot In The World
2007: SBPLI Long Island Engineering Inspiration Award Winners
2006: SBPLI Long Island General Motors Industrial Design Award Winners, Brunswick Eruption Champions
2004: New Jersey Regional Motorola Quality Award
2003: J&J Mid-Atlantic Regional Winners
2000: National Finalists
1999: Mid-Atlantic Regional Regional Finalist
Team 102
"Teamwork Is The Fuel That Allows Common People To Accomplish Uncommon Results." - Jeff Gordon
Unread 03-12-2006, 00:39
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Thumbs up Re: pic: Team 948 2-Speed Ball-Shifting Gearbox CAD Drawing
This looks good. Keep up the good work.
I have to agree with the weight issue.
Also once you have the hubs off you could put them a lot closer together making the box thiner.
I do not think there is more friction on ball bearing shifters than there is on a dog shifter. Also a ball bearing shifter can be made oil filled inside the shaft.
I also designed a Ball Bearing Shifter that is currently being manufactured. Once is done I will post pics along with a white paper. Thanks to Team 222 for the idea.
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 03-12-2006, 02:32
Who said this was for the shooter?
Unread 03-12-2006, 12:45
CraigHickman
Posts: n/a
Be wary, you must machine everything perfectly, otherwise it will shred itself. 114 built one of these last year, and had far too much fun with it, until we realized we had no weight for the pneumatics. However, during the offseason, this is a great shifting system. I encourage you to keep playing with the design.
Another tip is on the shifting plunger, you may want to mount springs on the part that forces the balls out, to reduce wear on the part. This is due to the fact that it needs to be able to lag until the balls line up with the grooves in the gear.
Good luck, and I highly reccomend this type of drive system!
Unread 03-12-2006, 13:51
AKA: Dave
I was looking at the Inventor files and it shows the shaft that is connected to the piston and the piece that pushes the bearings as two separate pieces. However it shows that the shaft that goes to the piston has a recessed and the piece that pushes the bearings has an ID equal to the diameter of the recessed. I hope that is understandable.
Anyway my question is how are you going to insert one in the other?
Unread 03-12-2006, 13:54
Billfred's Avatar
Billfred Billfred is online now
So, just to make sure I understand the concept--the piston moves the larger piece inside the output shaft, which forces the balls out into the gears, engaging the gear?
Unread 03-12-2006, 13:58
AKA: Dave
Thats exactly right. In this one I am assuming there is going to be springs as the shaft and the plunge are two separate pieces.
Unread 03-12-2006, 14:26
FRC #0948
Yes, that is true about the model. The model is not quite correct in that the larger end piece of the inner shaft (the one attached to the cylinder) will be removable. The reason the shaft is two pieces is so that the larger spool will be centered with springs on the smaller inner shaft, which will allow it to lag a little when it pushes the balls outwards which make shifting easier.
-Jake Felser-
Team 33's 2004 gearbox CAD files AdamHeard Inventor 1 03-10-2006 19:07
pic: My First time.....(CAD car drawing) negfrequency Extra Discussion 13 26-06-2006 23:12
pic: Team 865 custom 2-speed gearbox geo Technical Discussion 2 20-04-2006 18:13
pic: Vex 2-speed gearbox crazykid234 Extra Discussion 3 03-01-2006 20:18
pic: 222 2005 ball bearing style shifting transmission team222badbrad Robot Showcase 2 11-03-2005 14:17
