Go to Post At my age I don't celebrate birthday's anymore. I'd rather hang out with teenagers and build robots and be in complete denial about my aging. - Koko Ed [more]
Unread 03-12-2006, 22:39
Kirk Kirk is offline
FRC #0254
Kirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud ofKirk has much to be proud of
Send a message via AIM to Kirk
Re: New Miter Saw
Originally Posted by Dick Linn
I'm talking about chopping aluminum with a high-speed saw. Be very careful, and very wary. The least imperfection in the blade can cause a disaster. These are not the low speed "cold saws". Do be very careful!
I whole heartedly agree. There is a picture floating around here from last year where my index finger had a run in with the saw blade. But it was my fault. I did not clamp the material right. As with any power tool you have to use caution especially when you are using the tool or something that its not made for.
Unread 03-12-2006, 23:58
Gdeaver Gdeaver is offline
FRC #1640
Re: New Miter Saw
I was just about to post a thread like this. We've always used our schools old and abused horizontal band saw to cut our aluminum. The school does have a 10" miter saw ( not a low speed chop saw). I was considering Using that to cut our aluminum this year. I was looking at blades for aluminum and there are so many types I'm kind off at a loss at which would be best for cutting 6061 angle and bar. Most blades have at least 80 teeth up to 120 and many different rakes and tooth designs. What have others used? I also found abrasive blades just for aluminum. Has any body tried the abrasive ones? I really doubt there is any accuracy left in the old band saw and would rather not put the time and effort in it to use it again.
Unread 04-12-2006, 00:42
FRC #0254
Re: New Miter Saw
Stay away from abrasive blades. They generally leave very nasty burrs. We just go to Home Depot and but what ever the cheapest 80+ carbide tooth blades is. I don't see why you would need any special tooth offset or tooth angle.
Miter gears Aren_Hill Technical Discussion 2 04-09-2006 20:04
Curious Thing I Saw Joe Lambie Regional Competitions 3 27-09-2005 22:20
size of see saw? archiver 2001 5 23-06-2002 22:28
The Battlecry I saw Jeff Rodriguez Off-Season Events 2 17-06-2002 07:23
Saw New Delphi Comercial Joe Matt Chit-Chat 1 25-02-2002 21:52
