Go to Post Most teachers are not in it for the income, But they are definitely in it for the outcome. - Bob Steele [more]
Unread 04-12-2006, 01:17
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Re: New Miter Saw
As with most "what tool should we buy" threads that show up here on CD, I have an opinion so I guess I'll chime in on this one. First off, the type and size of miter saw you buy will depend on what you plan to cut. For FIRST use I assume you will want to use it to build practice field elements and maybe cut some light aluminum stock. Over the years, the majority of the stuff you would cut on a miter saw for constructing a practice field could be cut on a 10" non-sliding type saw. If you have the $ and space and don't mind the bulk of a 12" saw, then by all means go ahead.
I personally own 2 miter saws. A "good" one and a "cheapie". My "good" saw is a 12" non-sliding single-bevel Porter-Cable model almost identical to this one but without the laser. I bought it several years ago before laser lines were all the rage. It is a really solid workhorse of a saw. I have cut about a zillion 2x4s, 2x6s, 2x8s, 4x4 posts, 3x5 landscape timbers and even a few 4x6s over the years and it is still going strong. I have just completed a large deck using it to cut every single post, rail, and deck board because every board had to be individually cut to fit because the deck was not square or rectangular but sort of oddly shaped to fit and existing space. My point is Porter-Cable makes good stuff built to last and do the job. Our team has also used it extensively during build season for the practice field and to cut about another zillion feet of aluminum stock. We used a lot of the 80/20 Aluminum QuickFrame material on our 2006 robot and my Porter-Cable cut (and re-cut) every inch of it. 80/20 QuickFrame is basically like 1" box tubing with about 1/16" wall. Cutting aluminum stuff like the kitbot frame size material is also no problem. Cutting round stuff is another story. A while back I discovered that it isn't really a good idea to cut round tubing on a miter saw. I was trying to cut some thin walled aluminum tubing to use as spacers for the 5/8" keyed shaft in those black plastic helical gear boxes FIRST supplied in 2003/2004. Besides the fact that I couldn't get good cuts, it was just plain dangerous. A piece of cut tubing somehow got shot out of the saw like a bullet, went zinging past my head, ricocheted off a trash can behind me and flew about 150 feet across the street (I had the saw setup in my driveway) and landed in the neighbors yard after bouncing off their house. My point is be very careful using a high speed saw to cut aluminum. With a carbide tipped blade the saw will cut it fine but once the piece is cut in two the problems can happen very quickly. I have no problem cutting flat stock up and rectangular stock within reason but I will never cut round stock on it again. The largest aluminum stock I have personally cut was probably 1/2" x 2" 6061 flat bar. Also, don't try to cut anything too small like say shave a 1/4" off the end of a piece of something unless you are fond of the idea of bullets flying past your head. (It goes without saying but I somehow feel compelled to say it anyway, never, ever, ever, cut anything, especially metal on a miter saw without your safety glasses on and make sure there are no bystanders nearby or in line with the saw cut.)
Now, my "cheepie" saw is a 10" sliding compound from Harbor Freight. It was $99 on sale and is similar to this one. It is smaller and lighter than my 12" Porter-Cable and is easy for me/one person to move around so I usually grab it if I just need to cut a few small things like 2x4s or 2x6s. The quality of construction is definitely not anywhere near that of the Porter-Cable but it can cut a 2x12 and my 12" non-sliding Porter-Cable can't without flipping the board over. One interesting thing though is the cheap Chinese saw from Harbor Freight was spot on square right out of the box and has remained that way for the several years I have owned it. When I bought the Porter-Cable and opened up the box it was way out of alignment and I spent hours getting it right. During my recent deck building project I noticed that it has again gotten out of alignment and I am dreading spending the time to re-align it so that all the angles are true. The other major differences are that the "cheapie" 10" HF saw doesn't have near the power that the 12" Porter-Cable does (duh) and that the HF saw doesn't have an electric brake on the blade which makes it somewhat less safe to use than the Porter-Cable. All in all, I am very happy with both but each has it's use in my shop.
Now with all that said, if I had it all to do over again I would buy a DeWalt dual-bevel saw like this one or if I had the $$$ the sliding one like this one. The dual bevel DeWalt saws place the motor behind the blade so you can miter and bevel in both directions. In practice you can usually get around the limitations of a single bevel saw by flipping the material around but sometimes this is very awkward.
So, bottom line, if you are limited on funds and don't need to build a whole house I personally think the $99 saw from Harbor Freight can be very useful to a FIRST team. If you have the $ and prefer a solid built tool that will last forever then stick with the DeWalt. Don't get me wrong, I love my Porter-Cable and either it or it's brother made by Delta (same saw - Delta and Porter-Cable are the same company) are great saws but in hind sight I now see why all the contractors use those yellow Dewalts.
For the record, I'm not connected to any of these tool companies and own all sorts of power tools from Craftsman, Porter-Cable, DeWalt, Bosch, Harbor Freight, Black and Decker, Milwaukee, Ryobi, and others that I can't think of right now.
Unread 04-12-2006, 12:59
moojoe's Avatar
moojoe moojoe is offline
AKA: Zachary
FRC #1712 (Power Hawks)
moojoe is on a distinguished road
Re: New Miter Saw
just a small thing to add.
a lot of people will go for the non sliding saws for cost and they dont see a point in them.
when it comes to it though, the sliding saws are significantly safer then straight up and down saws, especially when working with people who may not have a significant amount of experience with a miter saw.
say when you hit a really rough knot in the wood (and if you cut a lot, you will), the saw tends to jump. either because you dont have an amazing grip or because its just to hard. when your cutting in an up and down fashion, and the wood catches, it will fly outward because of the angle your cutting at, and possibly hit you, or someone around you. when cutting with the sliding saws, you can pull it out all the way, push it down, then cut in a move that when the wood cuts, because of your angle, the wood will fly backwards, into the back board on the saw, and not into you.
not to mention, you can cut 1x6 or larger with the sliding.
just something to keep in mind. while you may not have a significant amount of money, its worth it in the long run for safety.
Unread 06-12-2006, 12:37
Dick Linn's Avatar
no team (Synergy)
Re: New Miter Saw
If you do cut aluminum or other non-ferrous metals, make sure the blade is designed and rated for that! Some are expensive, others not so bad. Harbor Freight used to have a 10 inch #46234 blade at a reasonable price, but it's either out of stock or discontinued. Home Depot carries the Freud Diablo SKU # 341031 for $55.
I also caution against nipping a bit off the end of a piece. If the piece is tiny, it can get jammed down in the kerf where the blade meets the base, or come flying around inside the guard. If both sides of the metal aren't clamped, things can be launched with disastrous results. Also take care that the blade is not dropped and that no teeth are chipped!
A band saw is much safer.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Miter gears Aren_Hill Technical Discussion 2 04-09-2006 20:04
Curious Thing I Saw Joe Lambie Regional Competitions 3 27-09-2005 22:20
size of see saw? archiver 2001 5 23-06-2002 22:28
The Battlecry I saw Jeff Rodriguez Off-Season Events 2 17-06-2002 07:23
Saw New Delphi Comercial Joe Matt Chit-Chat 1 25-02-2002 21:52
