Go to Post Maybe FIRST could get a sponsorship from Ikea, and we all could get flat-packed field parts with pictoral assembly instructions. And then all the parts could have funny names. - sanddrag [more]
Unread 02-12-2006, 00:42
rholokleolke rholokleolke is offline
First year programmer
FRC #0964
rholokleolke is on a distinguished road
Send a message via AIM to rholokleolke Send a message via Yahoo to rholokleolke
MPLAB IDE
Hello, I'm the programmer from team 964. Last year none of us knew how to do anything at our school because our entire team was freshman (only 5 people on our team total). I was learning how to program the robot but I could not get MPLAB to work at all. Deciding it was my lack of programming knowledge we got easy C I think it was. This year we have more people who have never done it. Our instructor wants us to give a demonstration for the new people and to teach them things before the kickoff. I tried loading MPLAB IDE and C18 and Ifi loader of the original cd from last year. Everything installs however it won't even compile the unedited default source code that I got off of the ifi website. I also have tried bloodshed C/C++ tutorials. Please someone explain what I did wrong and how to fix it. I loaded all the files into a new project when I tried to compile it. If you don't know how to fix it can you recommend a free compiler that works well. I might be able to use Linux's gcc either with cygwin or with knoppix. Thanks in advance.
First rule of technology if it doesn't work break it more.
Unread 02-12-2006, 06:42
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Re: MPLAB IDE
With the default code is a workspace file. Open that and try and compile it. Do you get any errors?
Unread 02-12-2006, 07:10
Electrical Engineer
Rookie Year: 1995
Re: MPLAB IDE
Chris is correct. We need more detail on exactly what errors you are getting in order to help you.
Rest assured that over 1000 teams use MPLAB to program their robots. It will work for you. We just need to find out what your stumbling block is...
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 02-12-2006, 08:22
Gdeaver Gdeaver is offline
FRC #1640
Re: MPLAB IDE
Every team should evaluate their programming abilities. If a team feels lost with MPLAB and has difficulty with getting going, then I strongly suggest they consider Easy-C. This will ensure that the team can program the robot. After, they feel comfortable with Easy-c then start on MPLAB. Is there another team in your area you could meet with to help with the MPLAB installation and get you going? Our team is in a similar situation. We have 2 students that I feel could handle MPLAB. One hasn't been to too many meeting and the other I feel should step up to a leadership position, leaving us with rookie programmers. After, last year's experience, I kind of like Easy-C.
Unread 02-12-2006, 13:39
FRC #0964
Re: MPLAB IDE
I know how to program now. I've made other programs that didn't have to do with first using bloodshed. There was no project file included. I'll try to download it again. I know how to use compilers and C. Last year I hated easy C because it was all drag and drop and I prefer a text environment over some cute gui when programming. My problem was is that after installing all the files on the cd it would not compile the default source code.
Unread 02-12-2006, 13:57
Re: MPLAB IDE
...My problem was is that after installing all the files on the cd it would not compile the default source code.
How did you install the files? Where did you obtain the default code? How did you go about trying to compile it? What did MPLab do when you tried? Be as specific as possible. We can't do a good job of assisting you if we don't have good information about the problem.
Unread 02-12-2006, 18:22
FRC #0964
Re: MPLAB IDE
I first installed the software following the instructions that came on the cd it said first install mplab ide. I installed that then I installed the c18 one as per the directions. Next I installed ifi loader. After all that was installed I restarted the computer. Next I downloaded the default source code from ifirobotics.com. There were no project files in the folder so I selected new project. From there I added all the .h and .c files in the directory. i attempted to compile it and it said there were errors in the code. I'm sorry I can't tell you the errors right now I will have to wait till tuesday to try anything again. When I do I am going to redownload and install everything. If I still get the errors I will post again with the exact errors that it gives me. Thank you for you help and concern.
Unread 02-12-2006, 18:30
Eric W. Jones's Avatar
Eric W. Jones Eric W. Jones is offline
Rack & Roll, baby!
FRC #1646 (Precision Guessworks)
Eric W. Jones will become famous soon enoughEric W. Jones will become famous soon enough
Re: MPLAB IDE
You shouldn't have to start a new project in order to use the default code. What I would do is simply edit the default code. Don't change any folder or file names. The compiler can't handle long file paths, so for best results, place the folder with your code on the desktop. This will make the source file name as short as possible. As long as you don't change any file paths the code should compile.
As for the errors in your code, what sort of errors were they? If there are syntax errors, you can double-click on the error given in the compile window, and MPLAB will show you about where the error is. If the error has something to do with a file path, follow the directions above.
Let me know if this helps!
2006 Boilermaker Regional
2006 Buckeye Regional - Third place overall
2006 Atlanta Finals
2006 IRI
2007 Boilermaker Regional
2007 St. Louis Regional
2007 Finals (hopefully )
2007 IRI
Why, yes. I do know what I'm doing!
Unread 02-12-2006, 19:21
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: MPLAB IDE
Theres a very strange thing that the C18 compiler does....
How many characters is the path to your project files? There is a limit to the number of characters allowed.
I would suggest trying copying all of your files to a directory near the root, in my case, i use: "C:\firstcode\<year>\<day/revision>"
Did that work? Post back here or PM either way. Hope that helps you, if you need other help i'm not a 1/2 bad programmer.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 02-12-2006, 23:15
Re: MPLAB IDE
...I downloaded the default source code from ifirobotics.com. There were no project files in the folder...
That's odd. There's definitely a FrcCode.mcp file inside the folder I get when I unzip the http://www.ifirobotics.com/docs/frc-code-2-28-2006.zip file. I suggest that you look again; if it's still not there, download a fresh copy.
Unread 03-12-2006, 22:44
teh_pwnerer795 teh_pwnerer795 is offline
AKA: !!Mitch!!
FRC #1392
teh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really niceteh_pwnerer795 is just really nice
Send a message via MSN to teh_pwnerer795 Send a message via Yahoo to teh_pwnerer795
Re: MPLAB IDE
Another question.
Have you stated in ur active project your Library path of the mcc18 ? Also have you stated a path for ur output directory. This can be found in Project/Buld Options/Project. I remember that that was my main reason why it would not complie properly.
srry my spelling can be way off.
Hope that helps
Unread 04-12-2006, 13:35
Electrical Engineer
Rookie Year: 1995
Re: MPLAB IDE
I just downloaded this zip file and unpacked it to a new directory. I then opened MPLAB and did a Project>Open and clicked on the FrcCode.mcp file. Then I did a Project>Build All and it compiled just fine.
There is no need to change anything if you have done the MPLAB/C18 installation correctly.
Mike
Mike Betts
Unread 04-12-2006, 18:35
Tom Saxton's Avatar
Tom Saxton Tom Saxton is offline
no team (Issaquah Robotics Society)
Tom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud ofTom Saxton has much to be proud of
Re: MPLAB IDE
-Q
Actually, I believe the only character limit is for the linker. The compiler can handle long path names. If you exceed the limit, you will get a clear error from the linker after all of the files are compiled. In that case, you will have to move the directory containing the project, but exit from MPLab first!
Tom Saxton
http://www.idleloop.com/
Unread 08-12-2006, 18:32
FRC #0964
Re: MPLAB IDE
Sorry it took so long for me to post I haven't been able to log on. I re downloaded the default source code off of ifirobotics.com. I opened the workspace and this time it was there. I talked to the only other person who had used the computer so far. Apparently he had moved it or deleted it or something. Don't ask me what he was doing with the computer considering hes one of the people who builds the robot. Anyways I opened it up compiled it no problem, made some changes tried again. Everything works. Thanks for the help and support. If I have anymore questions I'll be sure to post.
MPLAB IDE Problem amateurrobotguy Programming 10 26-02-2005 09:29
MPLAB IDE HELP Idaman323 Programming 2 16-02-2005 18:01
MPLAB IDE 6.60 Error mchan1111 Programming 8 08-11-2004 20:17
MPLAB IDE Project Specs Raven_Writer Programming 18 19-01-2004 15:53
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
