Go to Post Thank you NASA (except for Dave, his tormenting hints make us even) - Mike Schroeder [more]
Unread 04-12-2006, 11:41
Adama's Avatar
Adama Adama is offline
AKA: Matthew Eastman
FRC #2199 (Robo-Lions)
Adama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to allAdama is a name known to all
Send a message via AIM to Adama
constraints in assemblies
how do i mate a point to a plane. for example if i wanted to stand a pencil up on its point. physically impossible i realize but hey, its inventor and anything goes.
thanks alot
Unread 04-12-2006, 11:46
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: constraints in assemblies
My suggestion would be to mate the eraser end of the pencil to the surface and then offset it by the length of the pencil to get the tip touching the surface.
2001-2004: Team 100
2006-Present: Team 254
Unread 04-12-2006, 12:04
Elgin Clock's Avatar
FRC #0237 (Black Magic)
*Warning* I have never used Inventor.
Anyways, I would assume that if you made planes concentric between the assembly and the pencil (right & right, front & front) then it would automatically align itself in the direction you want it.
As far as the point (tip of pencil) to the 3rd plane (top), then you would be able to mate it and everything should be good and you would get your preferred 3rd axis constraint.
I use Solidworks, and this is how I would do it. I don't know if Inventor would do the same thing terminology wise (ie: mate vs contraint) but the concept should be there.
Unread 04-12-2006, 12:30
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Have you tried putting a 90 degree constraint between the point and the plane?
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 04-12-2006, 14:11
jacob07's Avatar
jacob07 jacob07 is offline
AKA: Jacob
FRC #0397 (Knight Riders)
jacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to behold
Send a message via AIM to jacob07
I have never used inventor but I think they have a point to point constraint. Creat a plane and put a point on the plane then exit sketch then constrain it
Unread 04-12-2006, 16:08
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
I just tried it, and it won't let you mate something to a geometric point unless it's a work point. Try creating a work point (choose the axis of the pencil and the conic surface of the pencil to create a work point at their intersection), then mate that point to the surface. That way you'll still be able to move the pencil around on the surface.
To constrain it standing up, create an angle constraint between the pencil axis and another edge or axis.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Unread 04-12-2006, 16:17
Adama's Avatar
thanks
one time i got something similar to work when i used someone elses drawing and they had used loft to create the point. i dont remember quite how it worked but i think i mated the plane and the work plane need to make a loft.
thanks alot
Unread 04-12-2006, 16:20
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
another strategy would be to cut the end of the cone of your pencil off and create a VERY VERY small plane to work with. In fact This is probably more realistic. Another strategy would be to round the tip off and use a tangent constraint.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Inventor popping sound for constraints is gone sanddrag Inventor 10 16-01-2006 14:55
Putting assemblies into other assemblies Crewmmbr21 Inventor 3 10-02-2005 16:15
Resizing Assemblies in Inventor Jeff Waegelin Inventor 7 25-02-2003 13:43
Driving constraints in assembly Jan Olligs Inventor 0 25-02-2002 07:11
Inventor Assemblies? Jon Lawton Inventor 11 27-01-2002 21:31
