Go to Post How many robotics kids does it take to turn on a light? - demosthenes2k8 [more]
Unread 04-12-2006, 16:35
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
pic: Dual sprocket Dewalt drive
Andy Brockway
Team 716, The Who'sCTEKS
Unread 04-12-2006, 16:37
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
Re: pic: Dual sprocket Dewalt drive
Andy, are you hoping to use this on the 2007 robot? If so, how are you planning on accomplishing the shifting mechanism (this was sort of an unknown when we were playing around with this a few years ago)? I see that there is a little notch in the shifting mechanism... would you like to explain?
Anyways, looks nice, as always. I hope you don't mind if I drop in on a meeting or two over my Christmas vacation.
Florida Institute of Technology
Ocean Engineering, '12
Unread 04-12-2006, 19:28
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
the dewalts generally are shifted with a servo.
Unread 04-12-2006, 23:27
Goldeye Goldeye is offline
AKA: Josh Hecht
FRC #0694 (Stuypulse)
Goldeye has a spectacular aura aboutGoldeye has a spectacular aura aboutGoldeye has a spectacular aura about
Send a message via AIM to Goldeye
How did you fit the second sprocket?
Team 694
2005 Championship - Galileo Semifinalist
2005 New York - Regional Chairmans Award
2005 New York - Semifinalist (Thanks 1257,1340)
Unread 05-12-2006, 08:05
Engineer
We are not planning on using the DeWalts next year for the drive. I was playing with the shifter using a servo but pulled it off before I took the robot out in the street.
The sprockets are attached like a sandwich. The outboard sprocket is type A, no hub. The inboard sprocket is type B, with hub. The hub is machined to reduce the distance between the sprockets. Both are piloted on the adapter. Clearance holes are in the first sprocket and tapped holes in the second. Simply run two bolts from the outside.
Jaine - stop by anytime, we are using the same general schedule.
Andy Brockway
Dual CIM Dewalt??? Joe Johnson Motors 4 30-01-2006 09:49
pic: Dual FP motors through a Dewalt XRP Andy A. Robot Showcase 5 18-02-2005 09:07
pic: Dewalt Dual Motor CD47-Bot Extra Discussion 8 10-12-2004 20:31
pic: Dual-Speed Drive Module CD47-Bot Extra Discussion 3 07-11-2003 13:45
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
