Go to Post This thread is just as lethal as any design your own game thread. - Schnabel [more]
Unread 01-12-2006, 12:19
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Encoder Pinout
Hi
For the upcoming year our team was thinking about using encoders.. i know that some of you have had success with the E4 shaft encoders from www.usdigital.com and it seems pretty easy to get them to work and hooked up. I was looking at the E6 version and noticed that it was 5 pin as opposed to 4. What is the Index pin used for?
http://www.usdigital.com/products/e6...x.shtml#pinout
Thanks
Unread 01-12-2006, 12:44
Re: Encoder Pinout
Scroll down a ways on that page, to see that the Index output "provides a single pulse per revolution." It lets you detect a specific absolute orientation of the shaft, rather than just giving information on relative movement.
Unread 01-12-2006, 15:22
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Re: Encoder Pinout
ah, alright that makes sense
so i would still be able to use the phase A and phase B lines like normal, correct?
Thanks
Unread 04-12-2006, 14:16
Re: Encoder Pinout
If you ignore the index output, the E6 is electrically identical to the E4. The A and B outputs work just the same.
Unread 04-12-2006, 21:43
bear24rw's Avatar
AKA: Max T
FRC #0011 (MORT)
Re: Encoder Pinout
Thanks
Tether Pinout roboticsguy1988 Electrical 4 15-01-2006 20:36
Joystick Pinout phrontist Electrical 0 21-02-2005 18:08
Spike RED Pinout Venkatesh Electrical 3 31-03-2003 21:42
Competition Port Pinout Rickertsen2 Electrical 9 15-01-2003 10:10
12V Tether pinout f22flyboy Electrical 10 01-11-2002 14:51
