Go to Post If you never reach out and experiment with different things, you will never have the courage to reach out again. It's only through experiments and experiences where we get to understand ourselves better. - Ken Leung [more]
Unread 04-12-2006, 22:35
ThienAn's Avatar
ThienAn ThienAn is offline
Programmer Boy
AKA: Mark
FRC #2104
ThienAn is an unknown quantity at this point
Send a message via AIM to ThienAn
MPLAB
what exactly is MPLAB? I know that it's a language that you can use for programming...and that there a different versions of it. Aside from that, I don't have a clue about anything else about it. =S (sorry, im just looking for language possibilities for programming right now, a language's pros and cons and such)
Team 2104! ^_^
Programmer
Unread 04-12-2006, 22:39
foote stepped in
AKA: E. Foote
FRC #0868
Re: MPLAB
MPLAB is an IDE, Integrated Development Enviroment. Of course theres different versions of it, as you will find that with all things (look at java, what are they on right now, like release 9?). MPLAB is made to program innovation first controllers (correct me if i'm wrong). It uses the c programming language, so it isn't its own seperate language. I think your only other option is EasyC... which is a graphically interfaced version.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 04-12-2006, 22:50
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: MPLAB
http://www.ifirobotics.com/docs/lega...2-apr-2004.pdf
You might want to read through that if your just getting started
www.ifirobotics.com
Hope that helps
Unread 06-12-2006, 15:12
shawger shawger is offline
Programming Subteam Leader
FRC #1732 (Hilltopper Robotics)
shawger will become famous soon enough
Re: MPLAB
MPLAB is not a programming language. It is the development environment that comes with the FIRST kit of parts. Basically, it is a text editor with project management and syntax highlighting that integrates nicely with the MCC18 compiler. We use the C programming language to program the robot.
I suggest you go over to wikipedia and look up the definitions for IDE, C Programming Language, and Compiler.
Unread 06-12-2006, 15:42
RKElectricalman's Avatar
RKElectricalman RKElectricalman is offline
Meezy the Mentor
AKA: Rameez
FRC #0384 (Sparky 384)
RKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really niceRKElectricalman is just really nice
Send a message via AIM to RKElectricalman
Re: MPLAB
MPLAB, as stated above, is an IDE, and It includes the compiler for the code too. It uses C programming, so unless if you're going to use Easy C you're going to have to learn how to program in C. I'd suggest learning C before the season starts, and getting a nice basis of it before trying Easy C as well. That way you'll have a nice understanding of everything before the season starts, ya know? Plus there's always more to learn, and getting a heads up on it will really help.
Extra info: MPLAB is made my Microchip technologies, and can be used in most C-based Interfaces, (i think )
ahhh Division Finalists!!
Unread 06-12-2006, 20:29
Steve S.'s Avatar
Steve S. Steve S. is offline
2008 FIRST Volunteer =D
FRC #1591 (Greece Gladiators)
Team Role: Webmaster
Steve S. is a jewel in the roughSteve S. is a jewel in the roughSteve S. is a jewel in the roughSteve S. is a jewel in the rough
Send a message via AIM to Steve S. Send a message via MSN to Steve S. Send a message via Yahoo to Steve S.
Re: MPLAB
Here is a link to the MPLAB Page on Microchip's Site
http://www.microchip.com/stellent/id...&part=SW007002
Unread 07-12-2006, 18:07
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
Re: MPLAB
MPLAB is, as has already been stated above many times, an IDE. It's used my most teams who are not using Easy-C to program their robot.
MPLAB serves 2 main purposes. First, it is used to write the code itself. It is, effectively, just a text editor for this purpose.
It's second, and more useful purpose, is as a compiles. If the compiler is installed, it can build your code. It takes your text, which means nothing to the RC, and makes it into a HEX file (and various outer file types along the way)
Unread 07-12-2006, 19:05
Alexa Stott's Avatar
Alexa Stott Alexa Stott is offline
All I do is twin.
AKA: elixir
FRC #0025 (Raider Robotix)
Alexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond reputeAlexa Stott has a reputation beyond repute
Send a message via AIM to Alexa Stott
Re: MPLAB
I do believe that there is a way to get Eclipse working, as well. I know that right now they're working on improving it. So that is just another option.
|Email:alexastott[at]gmail.com|Facebook|@zelixir|Google+|
[University of Maryland Computer Science, Psychology]
[Brunswick Eruption]
Unread 08-12-2006, 10:35
Re: MPLAB
Or VIM or another text editor providing you have the right makefiles. There is a thread somewhere around here for that.
Unread 08-12-2006, 16:56
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: MPLAB
Well... technically... not exactly. MPLAB itself is just an IDE, no more. The compiler, specifically C18 for our purposes, is what actually makes the code.
If you had some kind of issue with using MPLAB, you could write your code or word or edit or whatever text editor you want, and just call the compiler from the command line.
If you don't like C18, HiTech (not to be confused with HiTec who makes airplane servos/receivers) also makes a compiler for embedded processors.
On the Eclipse subject... theoretically using that IDE should work since most of what an IDE is is a text editor as said before. And since you aren't using an ICD or ICE there shouldn't be any issues with interfacing with the debugger. Personally I like MPLAB but have used Eclipse as well... if you really want to try it I'll bet it can be done.
If by MPLAB you mean C18 then yes you are correct as far as I know.
I use Microchip stuff around work and also for those fun weekend projects soooo... if anybody needs any help/questions answered just post or hit me up.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 08-12-2006, 18:06
Astronouth7303's Avatar
Why did I come back?
AKA: Jamie Bliss
FRC #4967 (That ONE Team)
Re: MPLAB
There's enough freeware editors that you should download one instead of trying to make Word work.
Also, I can almost guarantee that if you compile/link by hand, you will become discouraged and screw it up.
Just a word of warning: any alternative compiler you use will likely NOT be supported by us or IFI. (I know of no teams that don't use MCC18.) If you do use it, it MUST be able to read libraries created by MCC18.
It's not as hard as he makes it out to be:
  1. Get Eclipse
  2. Get the CDT (C/C++ Development Toolkit)
  3. an MCC18 toolchain plugin (prograid's original)
Also, I'm one of the people working on improving Eclipse's support of the MCC18.
MPLab to Easy C sbwprotoss9 Programming 1 12-01-2006 22:00
Mplab WesleyBalmer Programming 6 14-01-2005 15:23
mplab iso CmptrGk Programming 14 28-09-2004 20:11
MPlab error ryan_f Programming 9 24-05-2004 07:30
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
