Go to Post Scouting wins championships folks...not draft orders. - Andy Grady [more]
Unread 05-12-2006, 08:05
Andy Brockway Andy Brockway is offline
Engineer
FRC #0716 (Who'sCTEKS)
Andy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond reputeAndy Brockway has a reputation beyond repute
Re: pic: Dual sprocket Dewalt drive
We are not planning on using the DeWalts next year for the drive. I was playing with the shifter using a servo but pulled it off before I took the robot out in the street.
The sprockets are attached like a sandwich. The outboard sprocket is type A, no hub. The inboard sprocket is type B, with hub. The hub is machined to reduce the distance between the sprockets. Both are piloted on the adapter. Clearance holes are in the first sprocket and tapped holes in the second. Simply run two bolts from the outside.
Jaine - stop by anytime, we are using the same general schedule.
Andy Brockway
Team 716, The Who'sCTEKS
Dual CIM Dewalt??? Joe Johnson Motors 4 30-01-2006 09:49
pic: Dual FP motors through a Dewalt XRP Andy A. Robot Showcase 5 18-02-2005 09:07
pic: Dewalt Dual Motor CD47-Bot Extra Discussion 8 10-12-2004 20:31
pic: Dual-Speed Drive Module CD47-Bot Extra Discussion 3 07-11-2003 13:45
White Paper Discuss: Dual-motor, dual-speed drive transmission design CD47-Bot Extra Discussion 9 03-09-2003 10:40
