Go to Post gears won't care if theyre running underwater... the electronics will ;) - Cory [more]
Unread 05-12-2006, 17:18
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark
Mark and I did some work last night that has been overdue. We performed a test of friction coefficients on our wheels from AndyMark, Inc.. We got some interesting results.
Each wheel was tested in 4 ways:
Radial Static Friction
Radial Dynamic Friction
Transverse Static Friction
Transverse Dynamic Friction
Radial friction could also be considered driving friction, as it is the friction involved when the wheel is being driven forward and reverse. Or, it can be applied when the wheel is stationary and it is resisting a force from the front or back.
Transverse Friction is the ability of the wheel to move sideways, or scrub. This is also the friction involved when the wheel is stationary and a force from the side is applied to it.
Static friction is involved when the wheel just begins to move from a stationary position. Dynamic friction is involved when the wheel is already moving.
6 wheels were involved in the testing:
8" and 6" Plastic Omni Wheels
8" and 6" Aluminum Omni Wheels (not on website yet, but VERY soon)
8" Coolie Dualie Wheel (not on website yet, but VERY soon)
8" Mecanum Wheel
Here are results:
8" Plastic Omni Wheel
  • Radial Static: 1.07
  • Radial Dynamic: 0.9
  • Transverse Static: 0.20
  • Transverse Dynamic: 0.16
  • Radial Static: 0.9
  • Radial Dynamic: 0.8
  • Transverse Static: 0.27
  • Transverse Dynamic: 0.20
8" Aluminum Omni Wheel
  • Radial Static: 1.15
  • Transverse Static: 0.31
  • Transverse Static: 0.26
  • Radial Static: 1.05
  • Radial Dynamic: 1.0
  • Transverse Static: 0.29
8" Mecanum Wheel
  • Radial Static: 0.7
  • Radial Dynamic: 0.6
  • Transverse Static: 0.7
  • Transverse Dynamic: 0.6
The new Aluminum Omni-Wheels have the same roller geometry and setup as the Plastic Omni-Wheels.
<edit...
These tests were made on FRC-type carpet, with 30 lbs. of downforce on each wheel. The omni wheels were tested individually, while the Mecanums were tested in a right and left pair, with 60 lbs. of downforce.
(thanks for the question, Andrew Blair)
... end edit>
Andy Baker
Unread 05-12-2006, 18:16
foote stepped in
AKA: E. Foote
FRC #0868
Re: Friction coefficients for Omni wheels and Mecanum wheels from AndyMark
Correct me if i'm wrong, but doesn't the mecanum wheel have a theoretical value of .707? (cos45)... Which means you're doing fairly well.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 05-12-2006, 18:43
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
You seem to be thinking of efficiency. The coefficient of friction is independent of this.
Unread 05-12-2006, 19:16
Michael Hill's Avatar
I don't think you can have a theoretical coefficient of friction. My engineering professor said that it has to be measured.
Unread 05-12-2006, 19:30
Andrew Blair's Avatar
FRC #0306 (CRT)
Andy, what surface were these tested on? Game carpet probably?
-Sir Francis Bacon
-Albert Einstein
Unread 05-12-2006, 20:28
Yes, thanks. I edited my original note above with this info and also downforce info.
Andy
Unread 05-12-2006, 20:37
in between teams
AKA: Luke Van Oort
Is there a chance of future testing using other relatively common FIRST field materials like HDPE?
Team 1219: 2009 - Mentor
Unread 16-12-2006, 19:01
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Thanks Andy.. great info.
As we're prototyping with the 4" traction wheels from AM, and we're looking for more traction, does anyone have any thoughts for materials with a higher cof than the rough top?
Any thoughts would be appreciated.
Scott5736 (formerly Scott3137(formerly Scott358))
Unread 16-12-2006, 19:15
Joel J's Avatar
Joel J Joel J is offline
do you..
the brecoflex stuff.. Supergrip green, is it? 1.5-1.7 vs. 1.2-1.3, I think.
Joel Johnson
RAGE (173) Alumni, 1999-2003
Unread 16-12-2006, 19:23
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
This is what I see on there site. http://brecoflex.com/images.php?IMGID=82&TBL=submenu2
However, like you said, I thought they had something more grippy.
Unread 16-12-2006, 19:32
Joel J's Avatar
do you..
Ignore that. They sent out a message to all teams at the start of the 2006 season, and they reported the findings of their tests of several of their backing material on the carpet, diamond plate, and ramp.. Its in the white paper's section somewhere. That message aside, I don't think I have ever seen anything grip better than the green brecoflex treads.
edit: http://www.chiefdelphi.com/media/papers/1772
Joel Johnson
Unread 16-12-2006, 19:40
Engineer/Mentor
AKA: Scott5736
Hey Joel...
Thanks for the info... I had searched the white papers and somehow missed this. I'll give them a call.
On a side note, is your footer up-to-date? If so, I'll see you in Hartford and on LI.
Regards,
pic: AndyMark Mecanum Wheels Madison Technical Discussion 13 09-10-2006 00:29
Looking for Mecanum Wheels Armando Gonzalez General Forum 30 24-05-2006 12:54
AndyMark Omni Wheels Wayne Doenges Technical Discussion 11 25-01-2006 23:54
omni wheel instead of mecanum wheels Leav Technical Discussion 4 15-01-2006 18:53
